Question about Draper Replacement Surface ONLY for Ultimate Screen - 83x144"- Cineflex Projector Screen
Panasonic HDTV 1080i Screen
My neighbors son launched the Wii control dead centre of the screen, this has resulted in a 12 crack in the outer plexi glass, I have removed the screen and the diffuser and have noticed the plexi glass has a film covering it on the inside face, I though I would be able to replace the plexi but now I am not so sure,so basically..... What is the material on the internal face of the plexi and can it be replaced??? If not it is gonna be a real expensive game of Wii tennis!!!
Thanx in advance
Steve.
  • subsea Dec 10, 2007
    OK Thanx, the TV obviously still works but the screen is annoying to say the least, from your description the fresnel is seperate from the lenticular and protective, the lenticular i think is the black film on the internal side of the protective, so is there any paticular spec for the lenticular, I have a local glass store that can renew the protective, so if the lenticular is just a shading could this be applied as a film, for example like a window tint???
    Thanx,
    Steve.
    Thank you again, the model number is as follows:
    PT-50LC14-K
    Really appreciate your help,
    regards,
    Steve.
  • 71 Answers
Usualy Panasonic have 3 layers on the screen. From inside to outside is: fresnel, lenticular and protective. If only the one from outside is broken don't wory. It;s just protective and the film it's just a filter to improve the black level. You can use it like that but be carrefull because the lenticular it's not protected anymore and if you scrach it ... And do not try to clean it with anything else just dry rag.
Posted on Dec 10, 2007
  • Eduard P Dec 10, 2007
    No way! It's a lens and has to be replaced with original. It's about 200$ and you can order it via an authorized Panasonic center. I can give you the part number if you give me the exact model no.
    Sorry! I didn't know it's a LCD projection. This change a bit the problem. Has no protective screen it starts with the lenticular screen and a layer. I give you the both part numbers in order from outside to inside:
    LSGP0365
    LENTICULAR SCREEN
    LSMG0147
    SCREEN SPACER
    good luck!
I am looking for a new outer screen for my samsung hcp4752w TV as it was cracked, it is a kind of smoked plexi-glass can anyone help?
I can sell you a used one in good condition from my broken set, let me know if you're interested. Give me your e-mail address and I can e-mail you with details.
Dec 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
Cracked outer screen on projection tv
No it can't be repair only replaced.
Part# 4-090-943-01 $76.15
Freight charges may range from $45 - $150
Jun 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Toshiba 52 inch Screen
the outer trim just pops loose behind that there are several screws the plexi is held in by those crews i believe so once you take the screws out you can clean between the two screens
Feb 04, 2009 | Toshiba TheaterWide 46HM94 46" Rear...
Screen broken or cracked
you will need to call rca and order one from them
here is a customer service number you can call for more details on how to get the screen
877-794-7977
Dec 10, 2008 | RCA HD52W59 HDTV Projection Television
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Oct 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
How can I fix a light scratch on the plexi screen
There is a product for polishing platstic that removes minor scratches. I don't however remember the name of the product and if you do obatin it try it in the corner of the screen first to verify it won't do further damage to the screen.
Apr 23, 2007 | Philips 60PP9202 60" Rear Projection...
Draper Replacement Surface ONLY for Ultimate Screen - 83x144"- Cineflex Projector Screen Logo
438 people viewed this question
Top Draper Televison & Video Experts
Marvin
Marvin
Are you a Draper Televison and Video Expert? Answer questions, earn points and help others
