Question about HP Computers & Internet
BIOS system is disabled could it be the batteries
  • Chris Hingee
    Chris Hingee May 11, 2010
    What do you mean by disabled? Can you get into the BIOS configuration? If you can get into the BIOS configuration, can you save the settings?
  • HP Master
  • 3,051 Answers
Hello there:
If you remove the battery and leave in the power cord and start the machine and it works you may want to check to see if the battery is not charging or if the cord is faulty once you have the battery removed make sure to clean the contact area where the battery sits in ok and then see what happens ok?
best regards michael
Posted on Sep 09, 2009
Battery charging 80 extender
If you want solution for the problem that your battery is not being charged above 80%, then here's a solution.
Samsung Laptops have a feature to extend the battery life by stoping your battery charging after 80%. If you want a full charge, check the following two steps:-
1. Disable the Samsung Software "Battery Life Extender"
2. Enter the BIOS by keep pressing F2 button just after turning on your system. In BIOS, you will find an option Battery Life Extender(or something), disable it.
after following these steps you are done.
Dec 08, 2013 | Samsung R430 Notebook
Emachine d620 bios password
This works for me when I'm faced with this but its tricky unplug from wall remove battery, remove Hard drive locate bios battery this requires opening the laptop disconnect De-solder whatever it takes to remove the battery press and hold power button for 30 seconds with the bios battery removed reassemble with fresh bios battery or reuse old one "yuck" boot without hard drive into bios it should be at factory defaults hope this helps :)
Nov 08, 2013 | Computers & Internet
System battery voltage is low when i replace a new one its getting ok,but after a week the problem was back
make sure you are using the manufacturer rated system battery button. if it still is going dead then there may be a motherboard elec leak, bad battery compartment or your power source may be going bad? hope that helps you get direction
Jan 26, 2013 | Dell OPTIPLEX 745 PC Desktop
I forgot my bios password for lenovo t22
You will need to remove the CMOS battery to reset the mainboard. The Cmos battery stores your system configuration and your password. Remove the battery for about to 2 minutes to set your system to its default configuration and it will also disable the bios password.
Sep 01, 2011 | IBM ThinkPad T22 2647 Notebook
Everex GA3400 no video, no BIOS splash, nothing. Install PCI card
First look for a CMOS battery on the motherboard. If found, disconnect the battery and also disconnect the power cables from the system.
Wait for about 10 minutes and then reconnect battery.
Turn it on. If it remains same, try to re-seat memory modules and let me know if you get any beep sound when you turn on the system
Feb 18, 2010 | Everex GA3400 PC Desktop
Won't boot up
Hello my friend,for the first error it means that you must disable floppy disk from bios.Hit del while you booting and find the option floppy seek in the bios and disable it(usually boot options/advance boot options/settings) ,save and exit and you finished.For the second error you must replace the bios battery.On your motherboard there is one small round battery that keeps bios settings,take it out but first take off your power cord and push the power button for 10 secs so you will remove any electricity for not harming your system.Take the battery to a shop or electrical shop and buy the same/with the same model that is writing on the top.Very easy to find it and cheap too.After you buy this installed exactly as it was.With the letters on top and then plug you power cord and open your computer and make the settings in the bios i told you.Good luck
Feb 08, 2010 | Dell (002TR) Motherboard
Bios password reset
dear,
remove power cord from system.
pl set cmos clear jumper on motherboard and power on your cmos password is disable.
May 05, 2009 | Dell Microsoft Windows XP Home Edition
Removed my CMOS battery, but the BIOS settings won't disable
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and
3. Your reset is now complete
There might also be an option within the BIOS to "Load Defaults" if that is all you are looking to do
please see this http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/
hope it helps!
Nov 04, 2008 | IBM ThinkPad T30 2366 Notebook
I HAVE INSTALLED A TC/CARD ON MY MS 6786 MOBO
You mean your Video Card?
To disable the your MS6786 ONBOARD GRAPHICS on your PC.
- If you know ho to proceed the BIOS System of your PC? they have choices to change you settings
Disable or Enable.
Sep 22, 2008 | Computers & Internet
Reinstalling system & adding RAM - "system disabled"
Assuming we are talking about Bios only (not windows) what you describe (on a typcial motherboard) is impossible. Here is what I suggest.
1. Remove battery.
2. Set jumpers correctly meaning how they were originally.
3. If this does not work as normal then you will have to flash your bios.
4. You will need to know your motherboard model, get on the internet, go to mfg site, get the bios and flash utility (it will fit on a diskette) and go from there.
If this does not work simply comment back and I will get the message. We can go to step 2 then. Tango...
Feb 09, 2008 | E-Machines T2882 PC Desktop
Computers & Internet Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
