Question about Epson Stylus DX4450 All-In-One InkJet Printer
How stop printer put horizontal bands on page
How do I stop printer putting horizontal band across the page. This happens when printing and also photocopying. However, after a few photocopies have been made, the lines disappear but not after printed copies have been made.
Alternating dark and light bands
The most common cause of this is a failure in one of four earth circuit in the print head. It is not repairable
Nov 18, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Why is there a clear horizontal line within the printed line?
The print-head is like a paint-brush, in that it prints a "band" as it goes across the page.
In your case, some of the ink-jets are CLOGGED, and thus are not shooting ink as the print-head moves HORIZONTALLY across the page.
Run a few "print-head-cleaning-cycles", to try to unclog those ink-jets.
May 14, 2011 | Canon BJ 200EX InkJet Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Band of ink on back of printed page
The exit rollers need to be cleaned, but whats happening is ink is coming from the bottom onto the rollers. It needs to come apart and be cleaned and a mylar strip put in to keep the ink from coming up. A shop repair usually.
Jul 14, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Prints a page and random lines have a line running across
I had a problem similar to this where it would print 7/16" horizontal band blank and then a 7/16" horizontal band correctly. This problem occured systematically when printing text.
Called Canon support after a great deal of searching around on the web and they shipped me a new printhead. Problem solved.
If your printer is anywhere near a year or less old call them up and explain the problem. They were very helpful.
Dec 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Grayscale printing problem
Try printing from different application if it still doing the bandings on other application, tell me. Thanks
Apr 07, 2008 | Office Equipment & Supplies
Printer assistance
please change of it's printer driver software
and i think printer going ok
Feb 13, 2008 | Office Equipment & Supplies
Horizontal White Banding
Most likely cause is that a roller has degraded during storeage. Measure the distance from the centre of the first band to the second and from the center of the second band to the third. If this dimesion is fairly constant you can work out exactly which roller is causing the problem. The most likely culprit will be the Photo Conductor Unit. This will give a large dimension - (approx the 29cm??) A service manual should give you the dimensions (circumferences) of the rollers within the machine. If you have a spare pcu around, put it in and see if it makes ANY difference.
May 13, 2007 | Konica Minolta magicolor 2300DL Laser...
Epson Stylus DX4450 All-In-One InkJet Printer Logo
280 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
