Question about HP Officejet 5610 All-In-One InkJet Printer
Can't get hp5610 to work with imac running OS X 10.5.7.. Print will print pictures..but not word files..
4 Suggested Answers
SOURCE: 3055 sends to manual feed
Hi there
I've had a similar problem in windows instead of the mac, but it sounds like it's a
similar problem where the computer's telling the printer to use a
different sized paper to what the printer's been told is in the trays. For example, if, say, your document is set up for A4 sized paper, but the printer is set up to think it has Letter sized paper in the trays, it'll ask to have A4 sized paper installed in the tray instead.
Go into the system setup on the printer and select the paper setup menu.
Select Tray 1 and choose the right paper type and size from the settings (After you choose the paper type you have to go all the way back through the menus on the printer and choose the paper size as well)
Hope this helps!
Posted on Jan 02, 2008
SOURCE: Epson CX8400 Blank Pages
i was having the same problem and just got off of the phone with tech support who fixed the problem for me,
go into system preferences
print and fax
there you should see the printer cx8400.
remove the printer by clicking on the - sign.
then re add the printer, by clicking the +
the computer will search for the drivers and install them.
that should have you printing like a champ.
hope this helps.
WW
Posted on Aug 13, 2008
SOURCE: Will not print Photoshop file
Have you check to see if this is a postscript driver you are using?
Posted on Oct 31, 2008
Can't print from HP 2540 aio to my Imac PowerPc G5 OS X 10.5.8 The Imac keeps telling that the printer is offline.
A quick look at the HP web site for this printer shows that it only supports Max OS X 10.6 and later. These versions only support the intel processor based macs. Your PowerPC mac is, unfortunately, obsolete as far as Apple and the peripheral manufacturers are concerned and is not supported.
Dec 19, 2013 | HP PhotoSmart 7350 InkJet Printer
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
I'm trying to print a CD with Mac OS 10.6 on an iMac Intel duo with 3 gig memory, and get a message that I need to increase memory. Need a new driver? Ed
You will probably need to decrease the size of the file, if you work with a big art program you may have unnessesary (spelling?) layers floating in the background. Most printer like having bitmap images sent to them. Vectored images are printed as bitmaps unless you get into postscript compatible printers or some lasers. All else fails put the file on a jumpdrive and print somewhere else to start the process of elimination.
Sep 22, 2009 | Epson Stylus RX580 InkJet Photo Printer
Just purchased an iMac computer for my HP DeskJet 880C
You can log on to the hp site and get the current driver/printer software for your printer. Get the mac os version and install via usb. Download and install then restart your imac... then attempt a print...
Should work fine with an iMac.
K
Sep 01, 2009 | HP DeskJet 880c InkJet Printer
Problem with an installer for an application
right click on that shortcut, look at Properties, and then go to that location and try to delete..this should work..
May 18, 2009 | Apple Mac OS X 10.4
I have a Lexmark X4650 and have it connected wirelessly to my iMac running OS X 10.5.5. I would like to set the default to draft quality for all printing. I cannot see how to do this. Also i have failed in...
Try this... 1. Select your settings on the PDE (e.g. select paper type and print quality) 2. On the Presets, just below the printer selection, choose "save as" and name your settings. Everytime you print, choose File, Print then select your custom presets.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Sep 29, 2008 | HP LaserJet 1320 Printer
OS 9 ip print drivers
See: http://www.uvm.edu/ets/tcpip/?Page=ClassisOS-printing.html
Apr 15, 2008 | Apple iMac Desktop
Dell 3300 with OS X 10.4?
I've had a similar issue with a Netgear wireless print server. I had to configure it via Windows but was finally able to get it all working by using the Mac CUPS interface. http://shanecrawford.org/2007/27/cups-for-mac/
Dec 17, 2007 | Dell 3300 Print Server
HP Officejet 5610 All-In-One InkJet Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
