Question about Insignia Digital-to-Analog Converter for Analog TVs
Vcr my vcr doesn,t tape any more why
  • 24 Answers
This page has a diagram how to hook up your converter box to your VCR: http://www.ezdigitaltv.com/VCRs_and_Converter_Boxes.html
Posted on Sep 14, 2009
  • 69 Answers
Time for a new one....probably isn't worth fixing.
Posted on Sep 09, 2009
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
My tape player doesn't play anymore,
There are end sensors in the unit that are fed by a lamp and they burn out - I am guessing the lamp is out in the center of the tape.
There could be other reasons but without seeing the unit I can not determine remotely. I have repaired thousands of VCR in my 40 years in service.
Aug 09, 2012 | Televison & Video
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
When I push play there are lines and rolling and I can not control with tracking .
Always best to see if a good clean will do the trick. You can do this yourself better than a cleaning tape, but you can try one if you don't like the idea of messing with the VCR yourself. If you want to do the work, then get some Servisol Video 40 (you can find it on-line). Take the top cover off the VCR - disconect from the mains first. Then spray the servisol where the tape touches, especially the tape heads. If you don't know what to spray then after you take off the top of the VCR insert a tape and press play and watch where the tape touches. Remove tape turn off power and spray. You can use a cotton bud in the tricky areas too. Allow to dry and try a tape. You might have to do the clean again depending how dirty the VCR was. If the VCR lives in a smoke filled room that will make more work to clean it.
If it still doesn't stop rolling then you might have got a head fault.
Aug 20, 2011 | GE VG2040 VCR
I recently brought out my vcr and am trying to clean it with Maxell VP-201 VCR pro head cleaner... but it doesn't say how to use it. Do you know where to apply the cleaner on the tape before I put it...
You can usually apply a couple of drops on the tape itself as it will not harm. The tape itself might have a hole located on the cassette itself close to the see through cover. We normal tell people to drop a couple of drops into the tape area
Jul 15, 2011 | Maxell VHS VCR Head Cleaner Wet Type 1...
My VHS tape will not eject from the VCR. I have a message flashing stating ERR. What can I do to eject the tape?
Hello
The mechanism of your VCR has jammed with video casette tape. If tape ribbon has got twisted around the drum motor head, or the belt that connected to eject [capstan] motor has elongated, this type of fault will occur. Either it will play, rewind, fast forward of eject. Just replace the belts first. In most VCRs the user can replace the belt from underside. Let the tape is there, if it is in, replace all the belts. Belts can be bought from most of the electronic spare part shops at your town. It will come as kit type, each model has its own belt kit, and you have to give them the exact model number of your VCR. Just open the cover of the VCR, and look for tape ribbon twist if any. If it is there, remove it carefully without making damage to any other internal parts, especially to video head. If necessary, cut the tape film. If tape twist is only the problem, it will be rectifed as this twist has been removed. If this also doesn't help you, replace all the belts. OK.
Jul 11, 2011 | GoVideo Go Video DVD/VCR Combo
My panasonic AG DV2500 mini dv VCR hates loading and ejecting.
this loading problem in the AG-DV2500 is caused by a defective cassette housing. list price from Panasonic is about $375.00.
Oct 15, 2009 | Panasonic AG-DV2500 DV/Mini DV VCR
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Insignia Digital-to-Analog Converter for Analog TVs Logo
82 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
