Question about Kohler K-10416-BN Fort½ Single Control Kitchen Faucet with Side Spray...
Leaks from the handle
Water slides down from swivel.
  • 54 Answers
Replace o rings.
Posted on Sep 13, 2009
Rohl pull down faucet does not swivel but to one side
Improperly, maybe. Incorrectly, probably. Have the installer redo.
Jan 27, 2016 | Rohl Plumbing
Where do o rings go in a leaking delta kitchen faucet out of spout
usually there are 2 O rings under the swivel head turn water off then take the top off the swivel I use strap wrenches and replace the O rings use some plumbers lube on them . so it goes together easier and turns freely . Good Luck
Feb 14, 2015 | Delta Plumbing
How do you tighten the swivel part of moen faucet
you need to take off the handle and tighten up the bonnet nut becarefull not to damage the o-rings inside or it will leak yu just need to make sure and take care that the spout is all the way down before you crank down on the bonnet nu
May 11, 2014 | Moen 7840 Camerist Single-Handle Kitchen...
Rod stuck hydrant
Loosen the packing nut at the bottom of that rod that goes into the pipe/handle. Go to an autoparts store and buy a slide hammer. Unhook the handle from the rod and connect the slide hammer using any bolts etc that you have. Use the slide hammer straight up to free the rod. Tighten the packing nut back down to stop leaks, or DIG the whole thing up.
Feb 24, 2013 | Water Source YH-4 - 4 Yard Hydrant Is...
I have a delta in2ition shower head. The shower arm has a water outlet head that is screwed down onto it (the water outlet head is round like a ball and has a hole in the middle of it from which the water...
Take the gasket to your local hardware store and have them match it up.The answer is no, the gasket is not supposed to be split. It was probably tightened too much.
Jul 24, 2011 | Delta & Single Handle Shower Faucet
Just installed and is leaking from faucet body at joints.
If you used sealer (teflon tape) it shouldn't be leaking where the water hoses connect, unless it is still loose. If the faucet leaks water from ANYWHERE else (handles, swivel neck, spout) you have a bad faucet.
I would suggest if this is the case to replace the unit. Otherwise, remove your hoses and put pipe tape on the threads where the hoses connect, then reconnect the hoses, and tighten them down-don't strip the threads or break the connection. If it is a new faucet, it shouldn't leak anywhere when properly installed.
Hope this helps.
Dec 10, 2009 | Rohl A1676LPAPC Single Hole C-Spout...
533-50 kitchen faucet leaks above base mount at pivot body when water is on and the faucet is pivoting to fill other sink.It dribbles out on counter top.Seems not to leak if faucet stays stationary.The...
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Sep 27, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
Water leaking inside the washing machine
you need to replace the water valve there should be 2 screws in the back bottom corner of your control panel take them out then stand in front grab each side of control and slide foward control and then pick up and lean it back then you will see a 2 clips holding you housing of your washing machine and a plug undo the clips and unplug the wire once done that grab each side of the casing and swivel it foward then slide the bottom front foward now you can access the water valve to replace it please rate
Jan 06, 2009 | Whirlpool LSN1000LW Top Load Washer
Kohler K-10416-BN  Fort½ Single Control Kitchen Faucet with Side Spray... Logo
433 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
