Question about Samsung SC-X210L Mini DV Digital Camcorder
How to format a SD memory card for samsung
How do you format a SD memory card for samsung VP-X210L? When I put it into my camcorder the error message comes up "format not supported". The camcorder will not let me format the SD card asit states the format is not supported. I am using a Sandisk 2GB SD card.
    Genius:
  • 1,234 Answers
Hi Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Memory card error
    When you tried to format, did it complete formatting? If format failed then the memory is bad. Buy a replacement. Format should be completed in the camcorder for it work right.
    If format completed, and you can write to and read from the memory card on the PC, then there may be a problem with the camcorder card reader. Try blowing out the card slot with canned compressed air. (Don't use a tire inflator) And gently wipe off the contacts on the card with a QTip dipped in alcohol. Good luck.
    May 12, 2013 | Samsung SC-D103 Mini DV Digital Camcorder
    When I take my SD card out, it still says "DCF
    well as long as it works when u put the sd card in then its all good right?
    also
    1. DCF Full Error error message. The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You'll have to format the card with the Samsung camera. However, make sure you download any photos to your computer first.
    Mar 07, 2011 | Samsung ES30 Digital Camera
    Memory card error replaced card but still get error message?
    Is it the SD memory card? or the Micro HDD(4GB) you're pertaining to. In case of micro hdd not detected or error, micro hdd socket(CF) assembly has a problem most likely, need to be replaced. SD card; check your SD card's capacity, it can handle only up to 2GB or try to format your card elsewhere and re insert it again in your camcorder, if it will prompt you "FORMAT SD CARD?" you're lucky
    Feb 25, 2010 | JVC GZ-MC500 Memory Card Camcorder
    Memory card unformatted
    If there are sd card error, you cannot format your sd card. you may get messages like
    "No SD memory card inserted" messages appears when using digital cameras,
    "A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
    You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
    "Access denied", when SD card is corrupted or broken,
    you can fix sd memory card errors first and them format you sd card.
    Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
    SD Card Error
    The NV10 works with MMC and SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards.
    May 02, 2009 | Samsung NV10 Digital Camera
    Viewing Discs on Samsung VP-DC161
    RE; smasung DC 161(i) pal and possibly other models The reason why there is no disc message when there is definitely a disc is installed is because the disc programming has malfunctioned, Its because of Samsungs poor design, after powering up the camcorder and inserting a disc, the disc will load and a green flashing light appears for a minute or two while loading if the Samsung camcorder is switched off while loading the camcorder will essentailly self destruct and their is no remedy, however that does not mean the Samsung is completely useless,the camcorder can record on a 4 GB SDHC(max 4GB) card using the switch from disc to memory card
    Dec 16, 2008 | Samsung VP-DC161 DVD Camcorder
    I have a Samsung VP MX10 Camcorder. When I make a video, it plays back ok on the camera's own screen. But when I take the SD card out of the camera and put it into my PC (Vista), it only plays back the...
    Have you downloaded update of driver for Vista from Samsung website?
    You have not mentioned model number so I just can provide you Samsung Download link to see updates there.
    Sep 16, 2008 | Samsung Cameras
    Problems with formating samsung e250 micro sd card
    Did you try to format the card in the device thru Windows Media Player, or Rhapsody? If so, try formatting it thru My Computer instead. My Computer>Device Name>Right Click and select format. It is most likely NOT a virus if you have only put music on the device. It is most likely a corrupt file, or a database error. Best of Luck.
    Sep 12, 2007 | Cell Phones
    Samsung SC-X210L Mini DV Digital Camcorder Logo
    542 people viewed this question
    Top Samsung Video Cameras Experts
    Tony
    Lawrence Oravetz
    Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
