Question about HP Photosmart 3210 Printer
My 3213 uses 177 ink cartridges
I put the uk option 363 but my printer rejected them
I bought my HP Photosmart C6280 in Switzerland, using cartridges 363. Now I have moved to South Africa and I can only buy cartridges 177. When I put them into my printer it says "Incorrect Ink...
it is likely that you havr a mix of trade and host supply of ink cartridges. Even though HP363 and HP177 are compatible cartridges it is not the issue. Refer this article.
Hope this helps.
May 18, 2011 | HP Photosmart C6280 Printer
I installed 177 cartridges instead of 363 and of course the machine seems to know this! can it be programmed to accept the 177
No. Printer manufacturers vary the electronics on machines between countries. For example, you have a machine purchased from the UK that is the same as a model you can purchase in the US. The ink cartridges available in the US cannot be used in the UK machine because they essentially cannot communicate with each other.
Sep 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
I bought an HP C6180 all in one wireless printer 18 months ago while I was living in the US. It uses HP 02 cartridges which can not be sourced in the UK.There is a simalar 363 cartridge HP 363 but it is...
Oh yes HP can regionalize the printer for you. You need to call the UK HP and speak to their tech people. There is a specific reset that can be done and once it's complete you are able to use the 363 cartridges.
0844 369 0369 is there number and they do not charge for support for regionalization calls even if printer is out of warranty.
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
I HAVE AN HP PHOTOSMART C6280 ALL-IN-ONE PRINTER BROUGHT OVER FROM THE U.S.A. 3 OF THE INK CARTRIDGES ARE EMPTY AND I HAVE REPLACED THEM, BUT NOT WITH HP INK. THE MESSAGE ON THE SCREEN IS SAYING THE INK...
As the printer was bought in the US the printer is meant to use the #02 cartridges.
When you decided to replace the empty cartridges with refilled ones…the place you took them to be refilled more than likely decided to replace the little chip with a local flavour, which attempt to mimic original HP cartridges #363 (or what ever the number of those cartridges is where you are now). Hence now they are rejected by your printer.
But because the printer is only designed to use #02 cartridges it will reject every other cartridge/chip that do not have an #02 programmed into them….
You could try to call HP and explain them your situation and see if they can help you reset your printer to accept a different cartridge number …
Cheers.
Nov 08, 2009 | HP Office Equipment & Supplies
Re-configuring for european ink cartridges
i had thed same problem. after hours of trying different options i finally got it to work. i have a hp 3210 that i brought from the usa to irelnad and when i put in irish cartrtidges it said " this printer is cinfigured to use 02 cartridges" Iriss cartridges are 363. so what i done was , while the printer was turned on i held down the " Black" button and the "Color" button at the same time. Keeping them held I powered off the printer , keeping them held until the printer was completely powered off. when i turned the printer back on the region had being reset and it asked me to choose my language and country. chose " Ireland". Now works!!!
Apr 25, 2009 | HP Photosmart 3210 Printer
Use HP 363 cartridges instead of 177 for my Photosmart C7183
Phone HP.  After about a month hanging on, on their premium rate number, you'll finally be put through to someone who doesn't understand the problem.  Then, after your beard has grown another inch or two, if you're lucky, you'll actually get someone who understands the problem.  Some birthday's later, you'll be connected to a technician who can talk you through a simple number of keystrokes to re-configure the printer.
Reckon this cost me 30 UK pounds - seriously -  I had to call five times  but eventually it was done.
Apr 06, 2009 | HP Photosmart 3310 All-In-One InkJet...
Printer set up to use ink cartridge 177. Need to change to 363.
Hello, I bought my printer from my home country to USA. The ink cartridege HP 177 is not available in USA and I tried HP 02 but it did not work with it.,....
How to find a solution for this problem.
Mar 02, 2009 | HP Photosmart 3310 Printer
Let me inform you that printer would be set as per the zone and here is the information regarding the cartridge details.
Zone 1
Zone 2
Zone 3
Zone 4
02
363
177
801
Regards,
Sagarjd
Nov 10, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
