Philips 42PF9631D 42 in. Plasma Television
Problem for Philips 42PF9631D 42 in. Plasma Television
Hi, My philips 42
By passat122 on Sep 09, 2009
Hi, My philips 42'' plasma won't turn ON. I went to turn it on and the ''on'' button flashes red 7 times 4 seconds apart
Solution #1
posted on Sep 10, 2009
Not Rated)
swm6
Rank: Apprentice
Rating: 0%, 0 votes
I just had the same problem. I downloaded a service manual and give this a try http://www.servicemanuals.net . Turn on your TV and with the remote do the following Key in the code “123654” via the standard RC transmitter. This get you into a customer service mode and you can check your error codes.
After I got out this mode my TV worked. I think the TV was stuck in protection mode for some reason and by entering the service menu's it reset it.
I then entered the SAM Mode
How to Activate SAM
Via a standard RC transmitter: key in the code “062596”
directly followed by the “INFO” button. After activating SAM
with this method a service warning will appear on the screen,
you can continue by pressing the red button on the RC.
It will give you more info.
The TV worked fine after I exited these menu's.
I also did a software update as per the user manual and the TV seems to be working fine again.
Hope this helps
Was this helpful?
Yes
No
Popular Solutions for Philips 42PF9631D 42 in.
Questions and Unsolved Problems for Philips 42PF9631D 42 in.
Do you recommend Philips 42PF9631D 42 in. Plasma Television?
Answer
Answer
phillips model # 42pf9631d/37 will not turn on but clicks when pluged in
Answer
When my plasma displays words or graphics on a white screen, there are shadows behind the words.... (More)
Answer
turns on green then starts flashing red
Answer
I have a Philips 42PF9631D plasma tv. After the TV has been on for a while, a purplish pink spot... (More)
Answer
la ps3 no configura el 1080p en latv philips 42-pf-9641-d 10
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
