FixYa.com
Tags:
Jenn-Air Freezer Jenn Air Clear Cube Ice Maker
Jen aire ice maker not working
posted by BradRoz on Dec 10, 2007
Model #JCD2389DES Jen air ice make in freezer is no longer making ice, are their any simple ways to try and fix it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 30, 2008
Not Rated (0)
elhomspam
Rank:Guru Guru
Rating: 86%, 15 votes
change filter and defrost water lines if frozen
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 14, 2007
Not Rated (0)
roadbird383
Rank:Wiz Wiz
Rating: 83%, 38 votes
There are a number of things that cause this!! Is the arm in the up or down position.It must be down!! Up position stops the ice making.The next thing is making sure you have water to the units ice maker.Or if the unit has ice in the tray and it won't dump.You may have to replace the ice maker.
Can you Help with these Freezers problems?
Freezers
LBF6
unit has evaperater coil and... Answer This...
Freezers
Constantly running deep freezer
Our Gibson Model GFC15M4AW4... Answer This...
Freezers
Whirlpool chest freezer seems...
my chest freezer has a red... Answer This...
Freezers
freezer details
Not sure which code is the... Answer This...
Freezers
Frigidaire Upright Freezer
The freezer will work properly... Answer This...
Repair Service
Find Freezer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
