I have a Carrier 58DX080CC Forced air furnace that is leaking water onto the floor, but otherwise works perfectly. A service guy told me I need a new Coil, but it probably wouldn't pay to repair it, and that I should replace it. His quote to replace was about $6K. I found the part, Z7-58DX080CC-91CW at United parts supply for $890. The unit was manufactured in 1988 and is 90% efficient. What should I do? Buy the part and hire somebody to fix it? Buy a new one? The new price he quoted was reallly high, but I don't know how much these things cost. He thought the cost to repair it IF he could find the part was about $2,000.
  • 2 more comments
  • jeff14 Sep 09, 2009
    The filter is clean, so that's not a problem. I hadn't thought about the drain hose. I'll check that and get back to you. Thanks.
  • jeff14 Sep 11, 2009
    I have a tech guy coming over this afternoon. Right now there is nothing wet that I can feel, but there are plenty of water marks around the base of the furnace, and on the floor tiles around the furnace. During this summer we've run the AC about once a week, and the filter is clean. Can you give me advice on ways to get teh tech to test for the coil, the hose, or something else? The first guy I had here just said it was the coil, and left. Thanks.
    Turned out to be a clogged hose. So thanks!
  • jeff14 Sep 12, 2009
    Great solution that saved me alot of money. Thanks.
  • 10,515 Answers
If you are running a high efficiency forced air furnace then check the drain hose and make sure it isn't blocked or crimped. These furnaces tend to take a lot of humidity out of the combustion air (air from outside) and they are supposed to have a hose from the unit to the floor drain in your basement.
If you have hot water radiators, then you have a leak somewhere.
If you haven't even turned on the furnace yet but have air conditioning running through the heating unit then the condenser coil has frozen up. The main reason for this happening is a dirty filter. Turn off the A/C for a few hours to let it thaw and replace your filter.
About coil, i still have a doubt. I am not positive. To be on a safe side, either call some other tech or call Carrier at ;-
1-800-CARRIER for immediate customer assistance from 8:00a -5:00p (EST) weekdays.
Hope i helped you.
Thanks.
Posted on Sep 09, 2009
  • taran_2005
    taran_2005 Sep 09, 2009
    Thanks for your response!!
    That might be one of the reasons. Check and let me know once done!!
    Thanks.
  • taran_2005
    taran_2005 Sep 12, 2009
    That's what i initially thought :)
    I am glad that you issue has been resolved.
    Thanks for using ' Fixya ' and see you in Future if you have any doubts!!
    KINDLY CLOSE THE THREAD BY ACCEPTING THE SOLUTION IF 100% SATISFIED.
Polar water cooler leaking from inside
Oh, so it's your wife's fault, then :-) Just joking!
If this is one of the ones where you put a big bottle on top, chances are that there's a crack in the bottle itself -- this lets air leak in, and without a vacuum seal, yep, just keeps leaking onto the floor. Call your water guy. If you have a spare bottle, you can pour the water from the leaking one into the last one, and make sure the service guy knows the bottle is broken.
If not, whats the model number. If not sure, take a photo.
Jul 26, 2016 | Refrigerators
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
Oct 28, 2013 | Heating & Cooling
Why am I getting water blowing into the furnace and flooding the floor? This is happening after 12 years of service.
Hello, this can be either a clogged drain line or the tubing supplying the water into the humidifier is cracked. The size of the house has nothing tomdo with the water leaking into the Furnace.
Jan 04, 2013 | Aprilaire 550 Humidifier
Lennox air conditioner xc13 occasional hissing sounding like air being forced out of a sprinkler head when water is first turned on. water is also collecting on floor underneath the unit. this is a new...
That hissing sound, if it is on the inside of your home at the furnace then it is probably refrigerant running through the expansion valve. As long as the system is working ok I wouldn't worry too much about it.
The water on the floor indicate a leak in the condensation drain line or pan.
Jun 19, 2011 | Heating & Cooling
We had a new Carrier Weathermaker Infinity Gas Furnace installed in our home on 9-21-99.The Carrier people said the furnace was in good condition this past October.But prior to that as of April 2010 the...
Your Carrier guys more than likely are Carrier dealers. I would get a second opinion. Most qualified HVAC techs can work on any and all brands. It doesn't need to be a Carrier dealer to work on a Carrier. AND, if they replaced the control board and didn't test the heat, that's a fault on their part. Anytime we change a board or even a thermostat, we check ALL modes and functions. SECOND OPINION!!!
Mar 10, 2017 | Heating & Cooling
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Gas wont ignite
unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
Feb 23, 2009 | Coleman Propane Forced Air Heater...
Mobile home furnace with central air unit water coming out of fur
You had the condensate from the furnace come loose look for a pvc pipe coming off the furnace it drains the high efficiency heater. I would really check out your hot water heater too.
Nov 25, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
