Question about GE JBP60 Electric Kitchen Range
JBP75GS1WH 3 TOP BURNERS NOT WORKING
I have a GE stove that is a glass top and three of the four top burners have stopped working. I trying switching the switches around thinking I may have bad infinite switches, but this did not solve the problem. The oven works good and I have one small top burner working. It has been a good stove for me up, but need more than one small top burner. I checked the wiring by sight and there is no problems that I can see.
  • Anonymous Mar 24, 2014
    Sensor on one burner is always on. It turns on for a small amount of time say 5-10 seconds and stops. all other burner plates are working fine.. only the one with three sizes is broken.
  • 126 Answers
It could be bad connections at elements or bad elements a volt meter works good for this problem
Posted on Dec 10, 2007
  • Mike Freeman
    Mike Freeman Dec 21, 2013
    Our Kenmore Elite glass top stove blew out the rear burner. We turned it on and heard a pop and the power in the whole house went off, I replaced the burnt element but it still doesn't work. Any ideas, as the other 4 burners work fine.
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
Replace fuse on ge glass stove top
Maybe the top you can open above switches.
Mar 17, 2013 | GE Kitchen Ranges
The front right element on the stove top comes on full heat when the control is set to three or four. It doesnt cycle. just wide open throttle. My wife says if She turns it off and back on it starts...
The "infinite switch" is sticking due to burnt contacts. The problem will only get
worse until it is replaced. You will need the model and serial number, generally
located behind the lower drawer to get a replacement. (usually around 40 dollars)
Unplug unit or shut off stove breaker and remove (usually 4 screws) for the control panel. You can make drawing of the wires or use a cellphone to take several pictures
before replacing switch. (do not try changing switches around as they are different
amperages). Also check the burner socket itself, it may require replacement as
well. (They can short out on the chassis and ruin the switch). Hope this is helpful.
May 30, 2011 | Maytag PER5710 Performa Electric Kitchen...
How do I repair A knob that is broken off at the stem of my ge profile flat top stove?
You cannot repair this switch, you will have to replace it.
You will need to remove the cook-top and remove the glass top to access the switches. There will be a series of screws around the underside of the lip of the glass top that attach it to the burner box. Remove all of the remaining knobs and lift the glass straight off the box.
I would get your model number and order the replacement switch before starting the process.
good luck!
Jun 16, 2010 | Kitchen Ranges
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Jan 10, 2008 | Kitchen Ranges
Stove top ignition
I have a Kitchenaid Model KGCT365x and need to replace the igniter switch on the front right burner. Can this be done through the knock hole or does the whol glass top have to be removed? If it has to be removed, what is the best procedure to do this?
Jan 01, 2008 | Bosch HES 252/ HES 256 Electric Kitchen...
GE JBP60 Electric Kitchen Range Logo
399 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
