Help!! My WP Duet has died! Whirlpool GHW9200LW
Help!! My Duet has died! Worked fine until about an hour ago. Lightswere on and seem to respond to control panel. It just would not start acycle. Unplugged it for few minutes and plugged it back in. Now it'scompletely dead! No lights....nothing. I know that there are 2computers. Which should I replace first or should I just do both? Orcould there be another issue?? Any help is appreciated!! Rich
MCB (Motor Control Board) part number - 8182706OR
CCB (Computer Control Board) part number -
8181924
  • 1 more comment
  • RichDuet Jan 17, 2008
    Thanks for the help from this site.... NOT!!! I fixed it on my own. If you are having the same problem, let me know and I will tell you what I did.
    Gotohttp://www.appliancepartspros.com/index.... for low prices and free help!
  • Leevert Mar 27, 2009
    I have the same problem, with the lights coming on but it won't start. How did you fix it Rich?
    Leevert
    Problem Solver:
  • 20 Answers
CCB BOARD MOST LIKELY IF THERE NO POWER AT ALL ...
Posted on Apr 26, 2017
jsrock516
  • 5911 Answers
SOURCE: need instructions to replace the
Here ya go...follow this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you get stuck along the way and/or require further assistance, please let me know. I hope this helps you.
Posted on Jul 04, 2008
aborcass
  • 2651 Answers
SOURCE: How to replace whirlpool duet GHW9200LW baffles
easy repair, they simply slide over hte slits in the tib and firmly pull forard to snap/lock into place. there should also be a screw included in the kit, remove the top of washer (3 screws across the back of the lid)after removing hte main top toull see a black accordian like hose leading to the top of the tub assy, from the dispensor box to the left. remove this hose from the tub( pulls out of the hole), then simply turn the tub form the inside till the baffle you installed is at the 12 o'clock positon your screw hole will be right there. RESECURE THE HOSE, reassemble the top and your done!
Posted on Nov 26, 2008
  • 32 Answers
SOURCE: Control lock light on
take a good look on control panel i don't remember which button you should push and hold for 3 for 5 sec. to lock or unlock control panel (it also called child lock) let me know it help or not. thanks....
Posted on Jun 24, 2009
  • 1382 Answers
SOURCE: I currently have a Whirlpool Duet dryer model #
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Posted on Jun 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Whirlpool Duet GHW9200LW - the display
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Posted on Sep 30, 2010
Refrig and freezer not cold enough It was working fine until a few days ago. I put the temp controls to full cold and it is still warmer than normal. It is an older WP side by side model ED25PQXDW83
Only adjust one control one number at a time and wait 24-48 hours before adjusting again. Set both controls at the mid setting and start again. Check the coils underneath and make sure it has been defrosting. A problem in these 2 areas will cause your symptoms.
Eric
Oct 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need instructions to replace the rubber boot (door bellow) on the whirlpool duet washer GHW9200LW
Jul 04, 2008 | Whirlpool Washing Machines
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock is on, how do I reset the machine?
Press and hold down "end of cycle" button at right side of panel for 3 - 5 seconds. This is the child lock feature, do it again and the machine locks.
Dec 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
439 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
