Question about Dell Latitude D810 PC Notebook
Dell laptop battery has 3 lights flashing when hit battery tester
Dell laptop Latitude D810 battery has 3 lights flashing when press battery tester with battery removed. I am getting the 4 flashes of orange and then green when plugged in on the diagnostic screen. I suspect battery is going bad...but was wondering other than the obvious try full charging and fully draining the battery if anyone has tried anything else out that might get it to come back to life?
Thanks,
Dennis
  • 1dberry96 Sep 10, 2009
    After draining battery in Windows command prompt mode doing DOS commands. I plugged back in and now it appears to be healthy again. I will have to see how long it stays healthy now. Might just be temporary, but battery and diagnostic screen appear to both be content with a healthy battery now. It is 4 years old so will have to see how much longer it lasts.But so far took a Full charge and all is good after fully draining.
  • 1dberry96 Sep 11, 2009
  • 2,229 Answers
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Posted on Sep 09, 2009
Testimonial: "Thanks, that is a good tip. After a full charge to battery, I did a full discharge, started in command prompt mode, to drain battery with DOS. Now OK"
Flashing battery light
this usually means the battery is not or will not charge, sometimes you can click the batt icon, or rest your curser on the icon and it will give you a status of it
Mar 05, 2013 | Dell Latitude D810 Notebook
My Dell Latitude D810 won't even start up. All I have is the bluetooth light. Can you please help?
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 11, 2010 | Dell Latitude D810 Notebook
Have a Dell D810. Battery at 75% charge. When I
Get a 90w adapter is the only resolution. The D810 on a 65w adapter will:
  1. Disable the battery charger
  2. Run slower due to throttling
The 65w adapter MAY charge the battery if the computer is not running (Not sure on that)
Jan 25, 2010 | Dell Latitude D810 Notebook
Dell latitude d810 battery light flashes 4 orange and one green
This indicates an internal failure in the battery. While the battery may hold a charge and function, the system has determined an internal failure (Cell with low or no voltage etc) and the only way to resolve the failure is to replace the battery
Dec 19, 2009 | Dell Latitude D810 Notebook
Dell latitude d810 laptop won't full boot on just battery power a
Connect the AC Adaptor to the Computer and turn it ON. Then, open the Run dialog box and type "msconfig" to open Microsoft System Configuration window. On the System Configuration window, click on the Startup tab then check if the checkbox beside the "LoadPowerProfile" program is marked. If yes, then shutdown the Computer. Then, remove the Battery pack and clean the Battery compartment and the metal contacts using a pencil eraser. Furthermore, you may try resetting the BIOS to its default values after reinserting the Battery.
Restart the Computer and keep on pressing the F2 key until the "Entering Setup" text appears on the screen. Then, press the "Alt+F" key to restore the BIOS to the default configuration. Then, press ESC and Enter to Exit and save the changes.
Sep 04, 2009 | Dell Latitude D810 Notebook
No battery working
If your batterry is 3 years old u have to replace it. Its not charging properly
Apr 10, 2009 | Dell Latitude D600 Notebook
Ethernet drivers for dell latitude d810
Here's a link to the Dell Latitude D810 drivers download page. I would suggest that you also check the BIOS and download that if yours is out of date.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D810&os=WW1&osl=en&catid=&impid=
Good luck and please let me know how this works out for you.
~ Spoem
Mar 26, 2009 | Dell Latitude D810 PC Notebook
Dell Latitude D810 PC Notebook Logo
2,198 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
