Question about Kenmore Dryers
Will run but has no heat. replaced element,thermastat and fuse
  • Controlfrk
    Controlfrk May 11, 2010
    Full Model Needed if assistance is to be accurate.
  • 110 Answers
Okay, you need to check to see if you are getting full voltage, see your dryer will run on 120 but if it is not getting hot, then you are losing 120.
see from left side of outlet to middle you should get 120
from right side to middle you should get 120
total voltage is 220-240 volts in order for dryer to heat
Posted on Sep 11, 2009
Top thermastat has no voltage?
Are you getting 240v to the element ? If not it may be the timer , the centrifugal switch on the motor or a fuse . start by testing continuity in t he fuse then test timer .
GOOD LUCK
APPLIANCES R'EN
Dec 08, 2013 | Kenmore Dryers
Dryer does not heat but spins, what should i do?
Have you cleaned the vents out lately this could be your problem. The thermal fuse may be blown if so the operating thermastat may have caused it to blow. Check all thermastats , the thermal fuse, the high temp cutoff and the heating element. Be sure and clean the vents inside and out sometime something will get in the fan housing and slow the fan down or stop it.
Dec 05, 2010 | Amana NED7200TW Electric Dryer
DRYER WILL NOT HEAT UP I HAVE ALREADY REPLACED ELEMENT, THERMASTAT BY ELEMENT AND THERMAL FUSE CHECKS GOOD
This is a good website and should help you fix the problem, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 18, 2010 | Roper Dryers
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
Changing dryer belt
pop up the lid and you will notice a short heat element with blue thermastat, you will also notice 2 white wires that goes down to a fuse, that fuse is blown out, it is round on the side of the element housing. you need to get a Maytag fuse kit which will come in the package as a thermastat blue in color and 2 fuses, you will only use one of the fuses, one is for a gas and one is for electric, pink dot for electric, yellow dot for gas.
Sep 15, 2009 | Dryers
Dryer turns on but there is no heat. Is there a fuse  for the heating element? How to get to the heating element to change it if needed? Model DE309 Seie 01 Serial No. 733699   EC
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit,
that the motor closes to insure the motor is turning. Try another heat setting. There is
more than one thermostat. You may have blown the 'thermal fuse' too, which requires
replacement.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in
to the dryer. Hot air exit is restricted.
Jul 18, 2009 | Dryers
Whirlpool dryer not heating-
HI, To get to the element, you have to remove the lower front panel. You will see the element on the right side under the drum.
With the dryer running, you should have 240V the the two terminals on the element.
If there is voltage, replace the element. If there is no voltage, check the thermastats and the fuse. UNPLUG the dryer and check them for continuity. They should be closed.
This dryer is worth fixing. They are good ones.
I can help you with part #'s or answer more questions if yyou need.
I hope this helps
Vic
May 23, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
