Question about Welding Tools
I Have a Linde 160 and everything works except that the gas often does not shut off between welds.
  • ericeva Sep 10, 2009
    Where is the gas regulator located in my Linde 160 mig welder?? Eric Henderson.
    President:
  • 1,714 Answers
The gas solenoid is sticking. It may require that you open it up for a little cleaning. Next time it sticks open, give it a good tap with a screw driver and see if it closes.
Posted on Sep 10, 2009
  • 19,396 Answers
The gas pressure regulator, or the adjusting handle must be replaced.
If you are located in US you can get replacement parts here.
  • Ginko
    Ginko Sep 10, 2009
    I gave you the link with regulator adjusting handle, that is the part to be replaced.
    I won't be able to follow up, as answer got bad rating.
    Sorry.
    Bye.
Need wiring schematic for linde v160 migmaster
You should be able to get any replacement parts you want through Air gas / ESAB.
Reference:
http://www.millerwelds.com/resources/communities/mboard/showthread.php?19949-Opinions-please-Linde-MiG-Master-160
May 19, 2015 | Heating & Cooling
I have a linde v160 Migmaster v160, which keeps blowing the fuse???
you need a multi meter to test it, does it blow the fuse the second its switched on or when you pull the trigger, it could be the small transformer that powers the pcb, gas solenoid ,fan contactor or at worst welding transformer
Sep 12, 2013 | Miller Welding Tools
Porosity in welds
There is a time lag between the trigger being pressed and gas making it's way down the hose to the weld zone. That might be what you are experiencing. It can be mittigated a little bit by increasing the flow rate through the flow meter slightly and also making sure to allow some sag in the hose. The shield gasses are heavier than air.
There are sometimes issues with varying line voltage that can be intermittent in nature that can have an effect on the weld quality, these can sometimes be tied to a certain time of day as factories go online or shut down,
Loose connections inside the welder itself can be another source of inconsistency as can an overly sensitive trigger.
Jan 15, 2012 | Welding Tools
I have a Linde 160 MIG and it will not feed wire, seems to be motor not gun. . . Thanks
Just to make sure it is not the trigger switch, unplug the gun from the connector. With a clip try to bridge up the connector, if the motor does not turn then your gun trigger it's fine.
A new motor can be order it at any of your local welding stores. Try Praxair.
If this was useful to you please vote. thanks..
Feb 10, 2011 | Welding Tools
Gas won't shut off until power is shut off
With a tig welder it is designed to do this. The gas is used to shield your weld of all airborne contaminates. Your welder should have a flow on start of weld and what they call a post flow. This post flow protects your finished weld from contamination. You can preset it from 0 to 30 seconds on a majority of welders. I would recommend you set a postflow for at least 10 seconds and hold the torch above your finished weld until gas shuts off. It is doing this for a reason! Too Protect your weld from oxidation and other contaminates while the molten weld pool sets up! Hope this helps out!
Dec 28, 2009 | Welding Tools
My name is Eric Henderson and I own a Linde 160 Autoweld mig weld
instant. m/switch may need adjust ie trigg tabbs/ sticky contactor b/careful unplug mig
Aug 30, 2009 | Welding Tools
Leaky Linde
Is it comming out of the pump? if it is it's a Bear to get to.
Apr 12, 2009 | Clark Forklift Horn Button Switch , Cat...
LINDE HDA 300 TIG WELDER HIGH FREQ. PROBLEMS
The contact should have a gap .008 .
Mar 21, 2009 | Welding Tools
Bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Dec 18, 2008 | Welding Tools
Welding Tools Logo
388 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
