Question about Samsung S850 Digital Camera
We have a Samsung S85 and the lens is sticking. It either will not go in or will not come out without effort on our part. when it is stuck it beeps 4 times and shuts off. What can we do to fix this? Lubricate it? Is Samsung an unreliable brand of camera? I own several Nikon's Never have a problem. I never had problems with HP either.
  • 776 Answers
You can try with fully charged batteries. If this does not help, you may need to take it to a camera repair shop or buy a new one.
Overall there have been issues with the S85, as the lens gives a problem. Lubricating can be a good idea but you should not use any liquid that can not evaporate, however the best idea woudl be to go to the nearest Samsung dealer and have it checked.
Posted on Sep 09, 2009
Samsung S85 lens cover only closes halfway
Sounds like the lens cover will have got knocked off the guide rails, not much you can do, try blowing it with some compressed air incase there is any debris/grit stuck in there
Jun 22, 2012 | Samsung S85 Digital Camera
Samsung digimax d53 beeps then shuts off with lens stuck out
The camera lens is jammed, caused by dirt or worn out gears. a camera technician would be solution but not cheap, or you can take matters in your own hands and try a risky trick "NOT RECOMMENDED" take the palm of your hand and sharply hit it around the lens housing and applying power as you do so in an effort to get lens to retract, if you are lucky it will work or make things worse.
Mar 10, 2012 | Samsung Digimax D53 Digital Camera
Dropped camera zoom lens is stuck
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them. And am guessing that your lens may be crooked from the fall, so you may need to progress to Fix 7b first to straighten it before proceeding with the others. Good luck!
Feb 04, 2012 | Samsung S1070, S1050, S1030, S860, S850,...
Samsung S85 camera wont turn on. When the power button is pressed the green light flashes and the camera beeps three times than turns off. how do i fix it?
I quote the solution posted for another expert about this same problem...
My daughter has a Samsung S850, and returned from a weekend trip last night. She pressed the "Power" button and the blue light next to the button came on, as did the screen. The camera then gave a "buzzy beep" three times and shut-down. She decided the batteries were low and replaced them with ordinary AAA alkaline batteries, nothing special, and got the same result.
This morning I checked the voltage on the new and old batteries with a volt-ohm meter and found the old ones were low but the new ones were good.
I read this site and saw a comment that the camera worked after the lens was worked a little bit.
Upon a close look at the lens, I could see tiny grains of sand around the outside of the glass, so I got a wooden toothpick and gently worked the sand out with plenty of tapping on a solid surface to drop them from the area. I also worked the tip of a clean toothpick under what appears to be a soft rubber sealing ring on the outer surface of the glass.
After all this, when the "Power" button was pushed, the lens moved out and the screen lighted, and all the camera now seems to be working.
I should add that shortly after my daughter bought the camera, she lost some kind of metal or plastic ring from around the lens, and that left the "works" around the lens open to view: I can see two tiny screws the lens that are probably ordinarily covered.
Is the lens supposed to be covered by a curtain when power is off? From what I see, the lens is always uncovered. Maybe that lost ring held something else!
Its possible that
it needs repaired by samsung; You can follow the below link for tech support - http://www.samsung.com/uk/info/contactus.html
Hope this helps; send us you test comments.
Feb 26, 2011 | Samsung S85 Digital Camera
Hello i have a samsung camera model S85 and when i try to turn it on it does 3 beeps and doesnt even turn on.
Assuming you've tried the obvious test of using new batteries, it's unfortunately likely to be the infamous "lens error". This is such a common problem that someone has written a blog just addressing this one error. You can read it here - it describes it far more completely than I ever could!
Also, check this post.
Jan 21, 2011 | Samsung S85 Digital Camera
How do you print from a samsung s85 camera?
Dear friend,
Follow the step.
1. 1st install a printer on your pc.
2. install your camera .
3. Make default your printer for your camera.
4. on your printer, then c$onnect your camera with detacable and then on your camera.
5. go and print your photo from camera.
6. print will start.
THx
Jan 29, 2010 | Samsung S85 Digital Camera
More problems
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Aug 01, 2009 | Samsung S860 Digital Camera
Samsung S85 problem
I have had similar symptoms that seem to be due to battery power.
Using and OHM meter I find that the Samsung S85 eats batteries. If the charge drops to 1.4 something volts from a 1.5+ volt battery, the camera does not function properly.
The camera is nice an compact ... but I need to carry the same volume in batteries to make sure I can use it.
Jun 17, 2009 | Samsung S850 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Problem with camera
The lens is sticking, I had same problem, thought it was the battery. It kept doing 4 beeps and turning off, but the lens would be out.
Lightly lube the lens area with WD 40 worked, be real careful and don't use alot of it. My camera works fine now. I actually read the solution someone on this site, can't find it now, but wanted to post that it worked for me. I love the camera and was bummed it wasn't working. Works great now!
Aug 04, 2008 | Samsung NV10 Digital Camera
Samsung S850 Digital Camera Logo
684 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
