Question about Electrolux Icon Professional Ice Maker Free Delivery
Electrolux Side-By-Side Refrigerator making really load noise
Several problems now occuring. Water was coming from under the refrigerator, however, the bottom of the freezer was filled with water and partially frozen. We have had this problem before and have to take off the panel and chip away the ice and it works again. Now only crush iced is being made and the refrigerator is not cooling, although we can hear a fan running. We took a look at the solenoid and it looks like it has burnt up or something. We looked online a you can buy a solenoid kit to replace that, but that should only correct the cube ice problem.
  • 725 Answers
You have a defrost system issue! DON'T chip any more ice!! EEEKKS! You are lucky you didn't puncture the freon line! There is no repairing a punctured freon line!! We will send the correct parts to you if you will please provide your model number for this unit. Once you replace this defrost system. you will not have any more icing up issues. You must, however, defrost the unit out before you replace the defrost system. You can do this by unplugging your unit for at least a whole day and by placing a fan in front of the opened up unit to allow it to thaw out PROPERLY. BTW: I love the Electrolux Icon appliances. I hope this resolves your problem and I hope to hear back from you soon. We answer our phones from 7 Am until 9:30 PM CST.
Posted on Sep 10, 2009
Water and ice dispenser will not shut off
You need to replace both the solenoid for the ice maker and the water dispenser. Easy job, less than 1 hour. Parts should be under $50. Facing the back of the refrigerator the solenoids are located on the lower right behind the hardboard cover where the water comes.
The the replacement parts are a little different than what you have, and much easier to work with. Just cut the water lines close to the old solenoids (you don't have much extra to play with). You'll just push the water lines into the new solenoid valves.
Make sure the water is off and the refrigerator is unplugged.
Dec 23, 2013 | Electrolux EW23CS70IS Side by Side...
My refrigerator mades a loud humming noise
Hello Mona, thank you for your post!
Honestly it depends on when and how long the noise occurs. The only moving parts in the freezer on a side by side refrigerator are the evaporator fan and ice maker (if equipped). Also, you may hear the air damper in the refrigerator compartment moving when it is opening or closing. I recommend consulting a service provide and suggest that it may be normal.
Nov 10, 2013 | Electrolux EI26SS55GS Stainless Steel ...
Water dispenser won't stop
mechanism sticking somewhere and remains in open position. check and lubricate.
Nov 06, 2013 | Electrolux EW23CS70IS Side by Side...
Makeing a loud noise. sounds like it is coming
take back lower cover off check the fan see if there is somthing in it, clean the coils while your down there take front grill off and clean there too, make sure you put the back, back on it needs to be there or fride will overheat
Dec 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water collecting under crispers
Probably a plugged drain.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
Nov 28, 2009 | Electrolux Refrigerators
The freezer side is NOT freezing, but the refrigerator side seems to be cooling normally. I tried emptying the freezer compartment and setting the thermostat at maximum cold, but nothing seems to help....
Dear customer,
               We recommend you to do the follwoing checks
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the refrigerator or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak
Click on the highlighted words to know the steps necessary. Thank you..
May 07, 2009 | Electrolux Refrigerators
Electrolux Icon Professional Ice Maker Free Delivery Logo
452 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
