Question about Microsoft Xbox 360 Console
Not reading the diss - Microsoft Xbox 360 Console
    Problem Solver:
  • 5 Answers
Maybe you should try cleaning it
Posted on Sep 10, 2009
  • oskka Sep 10, 2009
    maybe you should try cleaning it
Cannot separate two parts of gun and nozzle. How to get them apart?
soak it in wd-40 over night. Twist the DISS connector to work it loose the retract the neck of this DISS connector and pull them apart. Use plyers if you need to. Change the o-ring inside the connector(hardware store can help you) and spray all connections and trigger mechanisms after each use, drain the hose and use pump saver after each use.
Jun 19, 2015 | Garden
Tip
Shwo me how to diss assemble samsung z720
When Logged in or After U insert PenDrive -
Just Open WinRAR and go to ur Drive -
Der U will find the Files with Virus.
Named>Autorun.inf and some other Rubbish file with .Exe
Delete Both the Files from it-
Play Safe-
Thank Meeeeeeee Friends !
on May 06, 2011 | Samsung SGH-Z720 Cellular Phone
I have a husqvarna 2348 lawn tractor 23 hp briggs intek 65 hours 5 years old biggest POS I have owned every year 300-400$ to keep running this year im stumped mower will start won't rev up if i wiggle...
To rule out all the switchs and micro switchs, you can diss connect the single black wire coming out from under the flywheel probably on the r/h side of the engine, if the engine runs ok it is an issue with one of the switchs, be aware the engine will not switch off on the ignition switch with this diss connected, if no better check the anti fire solinoid in the base of the carb float bowl, unscrew, turn the ignition on, the centre pin should retract fully back into the housing, if not replace.
Jun 15, 2013 | Garden
No spark
If there is no spark with a new plug and with the earth cut out wir diss connected , then its going to require a new ignition unit
Mar 05, 2012 | Garden
Poulan PPB 350 trimmer. I have replaced all fuel lines on trimmer, primer bulb,and plug. Doesnt want to start. Could the kill switch be bad and if so how do I test for this? How in the world do I get the...
The best way to check the switch is to diss connet the kill wire from the ignition unit itself, this will rule out the switch and the wireing up to the switch, with it diss connected remove the spark plug, place on the top of the cylinder and check for a spark by cranking the engine, keep the plug away from the plug hole when doing this. as for the fuel hose, the pipe should be long enough to come out through the filler cap hole, bend a loop in the end of a peice of wire, use this to hook the filter and hose to pull it out.
Jul 08, 2011 | Garden
How do I change the drum on the Canon 2880
Open the fron door ,diss/assably the developer unit.Remove the OPC drum and the chasrge corone unit.
Dec 11, 2009 | Canon IMAGERUNNER 2230 Copier
Replacing LCD inverter board on 5610
The better way is to get a service manual to be sure of follow the correct step to diss/asembly and not damage your laptop. You can get one from here, but you have to register to get access to the manual (about 5 eu).
http://www.nodevice.com/manual/newmans/acer/SG_AS5610_TM4200_BOOKpdf/get48623.html
Oct 26, 2008 | Acer Aspire 5610 Notebook
Phone stuck on vibrate
just diss assembly and check the speaker inside maybe lost the contact
Mar 05, 2008 | Cell Phones
Panasonic dmr es10
Some DVD recorders don't like certain types of media. Does this happen with all blank dvd+rw disks or just with that specific brand? If it's that brand then you should just use a different one.
Jan 07, 2008 | Panasonic DMR-ES10 DVD Recorder
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
