Question about Casio Exilim EX-Z750 Digital Camera
How to fix a lens malfunction in a camera - Casio Exilim EX-Z750 Digital Camera
  • Stephan Reichert
    Stephan Reichert May 11, 2010
    What in particular is the problem with the lens and what type of fix are you wanting instructions for?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Zoom lens wont closed, malfunction
You could have a stripped, jammed, or broken gear inside the lens assembly. Here is a blog about things you can try to fix the problem, if the gear is just jammed:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of the suggestions fix it, the camera will have to be serviced. You can take it into a local repair shop, or contact Sony Support on the web for an estimate.
Good luck and hope this helps.
Apr 18, 2011 | Sony Cameras
My kodak 3x optical aspheric lens is broken the pictures come out blurry and alot of contrast . how do i fix it?
If your lens is broken, then there is no other alternative solution than to get a new lens for the camera. Because the Light for the picture has to come through the Lens which focuses it. If it is broken or malfunctioning, you will need to put in a new lens. Thank you
Apr 02, 2011 | Kodak Easyshare V1233 12.1MP Digital...
Lens malfunction, "Lens error, restart
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 27, 2010 | Canon PowerShot S5 IS Digital Camera
It does'nt push the lens it says lens error. what will i do? my camera is nikon coolpix s500
The sled motor start malfunctioning it needs repair by an expert to open the lens section and fix the problem. Please contact any expert nearby, otherwise you must replace the complete optical zoom section.
Thanks
Nov 09, 2010 | Cameras
On my camera when i turn it on the lens keeps opening and closing and on my screen it says "turn off and on again" and when i do that the lens keeps opening and closing and it doesn't work. Can you help me...
This is the most common problem with dig cameras. The reason being that there are tiny gears inside the lens assembly, that operate it. When a tooth gets broken off, or some dirt, lint, sand, etc., gets in the lens assembly, a gear can get jammed. When this happens, the camera cannot "initialize" and be ready to take pictures. There is an excellent blog about this problem. It is listed under the lens error category, but it applies to all lens malfunctions, and the one you're having. Here it is:
Try their suggestions. They say about 50% of the cameras can be fixed trying their free fixes. If nothing works for you, and you decide to have it repaired, get an estimate first. The cost of repair can easily exceed the cost of a new camera. Good luck, and hope this helps!
Jun 18, 2010 | Cameras
Camera displays "Lens erros, restart camera"
I had this happen to my camera. The lens has malfunctioned. You will have to buy a new camera, or they might possibly allow you to send the camera in for a fix, but there is nothing you should or can try.
Good Luck
Cheers
dmklunk122
Dec 24, 2009 | Canon PowerShot SX10 IS Digital Camera
Washed camera and lens goes out but screen says lens error
OK, this is lens mechanism failuer due to water damage. the core micro board will start to malfunction in time. this repair will need to be initiated by a Nikon tech. you will need to contact the manufacture for a repair ticket and the nearest location of a repair terminal as well. the actual lens mechanism you will need is not available to the public and, the board as well.
May 27, 2009 | Nikon COOLPIX L18 Digital Camera
Camera lens malfunctioning
If the camera is 1 year or less try for a warranty replacement.
If older - throw it away and get the next one
Theses thing dont get fixed.
Aug 12, 2008 | Olympus Stylus 710 Digital Camera
Canon digital IXUS 60. Lens does not move in and out. Camera turns on but nothing happens. Unable to take photographs. Error message:- Lens error restart camera. Restarting camera does not resolve problem
I'm guessing that the lens is stuck. Either the cover refuses to open because something is wedged in or a mechanical malfunction. The camera won't work if the lens does not come out a bit. Take a look at the lens and examine why the cover doesn't open up. If it is a mechanical malfunction (meaning internal problem), might as well have it fixed. Be careful and keep your fingers off the lens. You may touch the cover but hands off the lens. Hope this helps.
Jul 17, 2008 | Cameras
Lens focusing ixus 30
With friends like this who needs enemy's [assuming the camera was like it when he /she gave it to you] A lens malfunction of any type is a costly repair In some cases a non repair because it would be cheaper to buy a new camera. Sorry to be harbinger of sad news
Aug 09, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Casio Exilim EX-Z750 Digital Camera Logo
361 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
