Canon iR2800 paper jam
I have a Canon iR2800 that the paper is jamming at the fixer. Also, need to know how to remove fixer.
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Mp600 paper ouput slot error will not reset
canon printer is telling me that i have paper jammed in paper out slot when ther is no paper in it can it be reset? or is it not fixerable by my self.
Apr 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam
What about you open the back of your printer & tighten it
Apr 17, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
Canon ir2800 is hanging after 2\3 copies what to do ?
How is it hanging.... What is wrong with it? Is it jamming or coding out? If it jams make sure the paper tray's are set to the same direction and size of paper in the paper tray. The knob for paper size input get's moved by the "Knob Mover".... Good Luck
Feb 28, 2010 | Office Equipment & Supplies
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Nov 10, 2008 | Canon imageRUNNER 5570 Copier
Paper Jam
Did you open the smaal door on the lower left to try to remove it from there.Or is it stucked in the fixing area.
Jun 07, 2008 | Canon IMAGERUNNER 6570 Copier
185 people viewed this question
k24674
