Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
I have a ice o matic that is old but still runs and freezs fine but will not harvest ?mabey relay
  • 867 Answers
Yes, relay or motor.
Posted on Sep 09, 2009
Ice o matic troubleshooting
If you have tried to take some time off of the freeze timer and bridge thickness is still to thick then depending on model.
1. Replace freeze timer.
2. Some models the timer is on the control board if so then you will need to replace the board.
Aug 27, 2014 | Kitchen Appliances - Others
Ice getting to thick and not dumping
go to the freeze timer which has off and on dip switches. take some freeze time out by moving the first switch to off this will shorten freeze time. Also check the harvest assist solenoid and plunger when it go's into harvest. make sure the machine is cleaned and check the cube plate to make sure that none of the plates are not loose this will cause ice to freeze between the loose spots and will not let ice come off the plate.
Jul 21, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice bridge to thick
there is a timer, adjusted by seconds, first make sure the condenser coil located under the ice bin is clean. the harvest is initiated by suction pressure once the pressure switch makes contact the time delay will time out initiating the harvest. you can fine tune the bridge with the time delay.
Jul 07, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
To big of icebridge
The ice bridge thickness of this machine should not be over 3/16" check the harvest assist solenoid and plunger during harvest to make sure it is operating. also check freeze cycle controller you will see it has some dip switches with off and on above the switches with numbers to the side of them you can take some freeze time out by starting at the top and moving the switch to off then let it make a batch of ice to see if this made a difference. The less time the thinner the ice. Time added to the controller the thicker the ice.
I have a ice o-matic model iceu220ha1 freezes but will not go into harvest
Go to Google put in model number ICE220ha1 when it comes up the fourth one down, Service parts manual The ice series under-counter... It is a PDF down load it then go to trouble shooting look for not going into harvest this will tell you what to look for.
Oct 24, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Does not go into harvest
There are two relays in the control box. One or both are brbably burned and will need to be replaced.
Mar 14, 2013 | Ice-O-Matic Ice O Matic ICE0400 Ice Series...
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
Oct 08, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
662 people viewed this question
Top Ice Kitchen Appliances - Others Experts
jasbo
jasbo
mike cooper
JoyEd Stevenson
JoyEd Stevenson
Level 1 Expert
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
