Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Trouble with access point
My son cannot connect to his Wii game system,since we've switched to this new modem.I looked on internet to find the password and that got us to the find access point screen.Now its saying cant find access point.Do you think its a problem with the modem or we just want be able to use the wifi with this particular modem?
  • 864 Answers
Try trouble shooting the device and see if that works. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Tip
How to connect your Nintendo Wii to the internet
In this tips and tricks guide I will go over the steps you will need to take if you wish to connect your Nintendo Wii to the internet. If you want to connect wireless you will need to be within range of a wireless access point. If you wish to connect via a wired connection(Ethernet to modem or Ethernet to router) you will need a Wii LAN adapter which is sold separately.
-Power on the console and press the A button to reach the Wii menu. At the menu, use your remote to select the Wii button at the bottom left.
-Now select "Wii settings"
-Now, hit the arrow on the right side of the screen to go to the next page and select "Internet"
-Select "Connection 1: none"
-Select "Wireless Connection" then select "Search for An Access Point"
-Select "OK" then the Wii will display all the wireless access points(wireless routers) that are in range.
-Select the wireless access point you wish to use.
-If the access point requires a security key, you will need to enter this key in. This key is set when you first configure your wireless router.
-Select "OK", then "Save Settings", and then "Yes".
At this point your Wii will now test the internet connection.
If you are using a Wired connection then you can connect the Wii directly to the router or modem and not use WiFi. Wii LAN Adapters are sold separately. If you have the LAN Adapter, follow the steps above up to the point were you select a connection type. You will select "Wired" instead of "Wireless. The Wii will now test your internet connection.
I hope this guide has helped you connect your Wii to the internet. Enjoy!
Regards,
G33k
on May 13, 2011 | Nintendo Wii Console
If i have wireless internect, how do i link my wii with it?
Wireless Connection
1. On the Wii console's main menu, click on the 'Wii button' in the lower left corner.
2. This will take you to the settings screen. On this screen, click on 'Wii Settings'.
3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
4. Select 'Connection Settings'.
5. Select an open connection, indicated by 'None'.
6. Select 'Wireless Connection'.
7. Select 'Search for an Access Point'.
8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search has completed, you will be directed to choose the Access Point that you wish to connect to. Click 'OK' to display the list of available Access Points.
9. Select your Access Point from the list of available Access Points.
If your connection appears as a closed padlock, then the Access Point requires a security code or passphrase. The security code or passphrase can usually be found on the security tab of your wireless router settings.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal. If possible, remove any obstacles between the Wii console and the Access Point. I've also found that changing the channel on your router to channel 1 or channel 11 can sometimes help with singal stability and strength.
10. Click 'Save' followed by 'OK' to save your connection settings...
11. ...and select OK again to start an automatic connection test.
If the test succeeds, Internet Setup is complete and your Wii conosle is wirelessly connected!
Jul 13, 2011 | Nintendo Wii Console
Connecting internet
The Wii has built in WiFi so if you have a wireless modem all you will need to do is go to the Wii settings menu and select Internet, Next choose Connection Settings then select Connection 1. Here you will have the option to choose a Wireless conection -OR- Wired connection. If you have a wireless modem or Router click Wireless connection and choose Search for an access point then
select your access point from the list. Save then start a connection test.
If you do not have a wireless modem or router you must buy the LAN Adapter which you will find here http://www.amazon.com/Wii-LAN-Adapter-Nintendo/dp/B0014KM2KG. You will need that to connect a ethernet cord from your modem to the Wii. You would choose Wired connection and click ok to start the test. Good luck and have fun (",)
Jan 04, 2011 | Nintendo Wii Console
How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    How do i get wii shop chanel
    Hello
    To get to wii shop channel first you need to configure your system
    Configure your Nintendo Wii for a wireless Internet connection. The only way to access the Wii Shop is by having an Internet connection and a wireless router. The Nintendo Wii has a built-in wireless router that can pick up signals from wireless Internet connections. Make sure that your wireless Internet router is close enough so that the Nintendo Wii can pick up a signal.
    Loading Wii Shop;
    Use your Wii remote to select the Wii Shop from the main Wii channel menu. The Wii Shop is located in the top right-hand corner of the screen. If your Internet access is not set up yet, then you will be prompted and automatically brought to the Internet Configuration menu. Once your Internet is set up, you will either be brought back to the Wii Shop or the main channel menu.
    Navigating the Main Menu
    Look at the main Wii Shop menu. Here you will be given two main options with a couple of general options at the bottom of the screen. The first option is to look for games for the virtual console. The Virutal Console contains games from past systems like Turbo Grafx 16, NEOGEO, NES, Super Nintendo and Nintendo 64. Once you have loaded the virtual console menu, you can search games by most popular title, new titles, system, genre or price. When you have found a game that you are interested in, press the "A" button to see a more detailed description with a couple of screen shots, and find out how many Wii Points the game costs.
    Wii Points
    Purchase Wii Points directly through the Wii Shop by using a credit or debit card. You will use the Wii remote to point and select all of the card holder information. The minimum amount of Wii Points you can buy is 1,000 for $10, so if you want a game for 700 Wii Points, then you will have 300 points left over for future purposes. Instead of using a credit card through the Wii store, you can purchase a Wii Points card at a local retailer. These cards come in different point values, and 100 points represents a dollar.
    Downloading the Software
    Finalize your game purchase by confirming how many Wii Points will be deducted from your account. Once you have done this, the game download will begin. While it only takes a few minutes to download, you can see the progress by watching a Mario character jump and hit a brick. Once he has reached the third brick, your download is complete. From there, you can continue to shop in the Wii Shop or play the game.
    Wii Ware
    Check out the other option that is labeled as "Wii Ware." Wii Ware is a lot like the Virtual Console, but everything created here is new and original for the Wii. You can get updated channels like the new Photo Channel or get exclusive Wii Shop games like "Midnight Pool" and "Family Table Tennis." The games here actually are interactive Wii games, and you can get the full game for a lot cheaper than a new Wii game from a store.
    Oct 10, 2010 | Nintendo Wii Console
    I took my wii to my sons house cant get internet service on my
    First you need to have a wireless internet connection,
    next you need to turn on your wii and go to wii system settings
    then scroll over to internet
    next go to connection settings and choose connection 1 2 or 3
    choose wireless connection, then choose search for an access point
    then it will give you a list of connections choose the one thats yours
    and if you put in a passcode with your wireless router you will need to input that
    after all of that it will start a connection test and if you did it correctly it should say... The connection test was successful. Perform a wii system update now?
    Congrats wii your new wii Wi-Finess
    May 01, 2010 | Nintendo Wii Console
    Cannot connect my ds or nintendo wii to buffalo wca gaming access
    If as "wired internet " you mean HI-SPEED internet access then .... Follow the instruction as per this manual
    Be Sure it's connected to your Hi speed Modem.
    If you do not have Hi speed connection It will NOT work at all.
    Dec 30, 2008 | Buffalo Technology WCA-T 802.11b Wireless...
    Connecting my wii to the internet
    to connect your wii to the internet connect to the following link or read the following instructions
    http://systemsetup.nintendo.com.au/Connecting_Online
    to connect your wii to the internet you will need to provide a wireless internet access point for it to find. you will need:
    a computer connected to broadband internet
    a wireless router OR Nintendo Wi-Fi USB Connector OR Wii LAN Adapter
    your wii console to be nearby all of the above
    If you are using the LAN Adapter you must plug the USB connection into the back of your wii console and the other end to your internet modems ethernet port. (follow steps below)
    if you are using a wireless connection follow steps below.
    Turn on your wii and on the main menu select 'wii' in the bottom left hand corner
    On the next screen, select 'wii settings'
    Select 'connection settings'
    select an open connection indicated by 'none'
    select the corresponding option, Wired or Wireless connection
    Wired:
    Wireless:
    Select the corresponding option, Search for an access point or Nintendo Wi-Fi USB Connector
    the wii will search for an access point, select the access point you wish to connect to, and save the settings
    The wii will now do a test connection and do a system update, the wii will now use that connection point to acces the online services
    hope i helped!!
    Sep 19, 2008 | Video Game Consoles & Games
    Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
    259 people viewed this question
    Top Westell Wirespeed Computers & Internet Experts
    Prashant M
    Prashant M
    arnold balmaceda
    arnold balmaceda
    Level 1 Expert
    Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
