Question about Xerox WorkCentre XD120f Copier
Paper keeps getting jammed and is covered with ink powder. Looks like part of the reel on the left side is broken on the cylindal shaped thing. Can that part be replaced?
  • 388 Answers
That cylindrical thing is the drum; the drum is photosensitive, meaning it is sensitive to light much like film in a camera. If paper is jamming and is covered in toner, that means the drum is possibly losing its effective properties and it is not being cleaned properly. The drum can be replaced; contact a Xerox Rep for service.
Posted on Sep 16, 2009
I get broken gear in my hp officejet pro 8500a
Someone pulled hard on jammed paper to remove it from the printer. This has broken the small plastic paper advancing gear on the left-hand side of the printer (have seen this mistake a number of times). The printer is broken and cannot be fixed, and it is time to purchase a new one. What you and everyone needs to learn from this is to NEVER pull hard to remove paper out of your printer. Be careful, and open the access doors to get to it.
We would suggest that you upgrade to an HP 8600 series printer and if you print more than 500 pages per month you purchase an AdaptiveInk continuous ink supply system (CISS). Adaptive Ink Continuous Ink Supply System Home Page Adaptive Ink HP Pigment ERC
Mar 12, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Dec 03, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
Message says; Paper jam. There is no paper in it. Tried turning off and back on, resetting. Nothing, same message. Any ideas? Thanks, Niki
Open the back door and look in the middle of the back cover, there's a black plastic sensor lever that must move up and down freely as the paper passes. That lever gets sticky and needs to be cleaned with alcohol so it can move freely again. You may need to remove the back cover with 2 phillips screws to gain access.
Please rate my response!!
Jan 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper feeds only from left side and gets jammed
Looks like the feeding mechanism is stuffed.
Perhaps try and get a broken one of some trade website and replace the mechanism, but MP210 is pretty cheap model this days and my personal recomendation is to bin this printer and buy new one.
It will save you some time and frustration.
Dec 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
HP C4385 display reads Paper Jam continuously
check the paper jamed or not other wise try to reset your printer
Oct 03, 2009 | HP LaserJet P2015dn Printer
Phantom paper jam . Samsung clp300. Flashing red light
you clean your printer drum unit wast ink poder drum open and wast ink
Jul 21, 2009 | Samsung CLP 300 Laser Printer
Paper jam error
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 22, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Mar 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Canon MP530 shows paper jam, when paper is not jammed.
First – diagnose your problem. In my case the first roller which feeds the paper through the ADF (under small black flip up cover on top) was not turning. Hence no paper advance and error claimed a paper jam (it wasn’t – just a failure to advance paper)
The cause turned out to be a stuck gear turning that silver rod at the top. A bit of household oil has worked a charm.
To get at the gear, unhinge the ADF cover retaining tie (black flexible plastic stopping it opening all the way). Just lift it up and roll over towards printer.
Then unscrew one screw next to that tie. Gently prise plastic cover off by lifting up from left hand side (near that black tie). It should rotate off. Keep power on and fingers out.
Put a few drops of oil on top gear. Place paper in ADF and attempt a batch scan operation. Gears should turn and lubricate parts. Repeat.  Once working, replace cover, screw and tie.
Mine had seized months ago and is now working fine. Hope yours does too.
P.S. Get a Continuous Ink System (as sold on eBay) - awesome for an ink guzzler...
Sep 08, 2008 | Office Equipment & Supplies
Photosmart 3210 all in one printer
Turn the printer around and open the door you will see paper jam.
Jun 30, 2008 | HP Photosmart 3210 Printer
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
