Question about Proview PL926WBi 19" LCD Monitor
Proview pl926wbi 19 inch monitor case removal
I have this brand of monitor . i have removed the base and 4 screws on the bottom and i can't get the case to split . would you have any suggestions for this problem? thank you.
  • bobcat3862 Dec 12, 2007
    thank you for your advice macspt . i did exactly like you told me and the case came right apart. i got to the power supply board and it looks like there might be capacitor problems .there are three 470uf caps with a slight buldge from their tops. is there a way a person can test the power supply board? if so is there any advice you could give me for this procedure. i am using my old gateway crt monitor and would really like to get the proview up and going again. thanks again macspt! hope to hear from you soon
Hey Bob,
I just did this and the following worked for me.
1. Orient the monitor so the base is facing towards you and the top is facing away from your. Make sure the monitor is LCD up.
2. Grip the gray plastics just above the buttons and flex it up and towards you. You should be able to see the button control panel.
It should flex enough for you to rest the bezel and screw holes on top of the underside bezel. When doing this you have to wedge your finger tips between the LCD panel and the gray plastics to separate it. The trick is not to apply too much pressure to the LCD panel itself so you don't damage it. Almost all your pressure should be applied to the gray plastics as you lift "upwards" away from the LCD.
3. Once you have done this, you need to slide the bezel away from you towards the top of the monitor in order to release the side tabs and the top tabs. I found the best way to do this is to push upwards or away from you along the bottom left and right corners of the monitor and move upwards along the side of the monitor.
4. Once you have release the side latches the whole bezel should just slide upwards or away from you.
Note: When replacing the bezel you need to start from the top and insert the top tabs first. Then align the side tabs and last align the bottom button portion of the bezel.
Posted on Dec 10, 2007
I understand that the power supply or something like that could be my problem, how do I get it open to inspect? Which pictures on your photobucket is the ones I need to look at? It is the PL926WBi Black...
I do not have this model in my Photobucket site yet.
Here is where you get the set of caps from: http://lcdalternatives.auctivacommerce.com/Repair-Kit-Proview-PL926Wbi-LCD-Monitor-P1660430.aspx
To open it up, you will need to remove the base and any screws on the back, then use thin flat blade screw driver the crack open the case starting at the bottom edge and work your way around, do not completely open it up, once you can get your fingers in between the front and the back of the case, lay the monitor face down on soft surface then pull up the back case. You may break some of the plastic finger hooks, not much you can do about that since they are one-way fingers, go in easy but gard to remove.
See example here: http://s807.photobucket.com/albums/yy352/budm/ACER%20AL2017%20BMD/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Mar 05, 2011 | Proview PL926WBi 19" LCD Monitor
I need a base for a 19" PL926WBI LCD monitor. Have
i have the same monitor and it flashes on and off! i am willing to sell if you want to buy it
Dec 12, 2010 | Proview PL926WBi 19" LCD Monitor
I need to know how to open the monitor casing for the proview PL926Wbi
Remove all the screws and stand first, then use thin flat blade screw driver to crack it open at the bottom edge of the case and then work your way around and becareful on the ribbon cable attached to the front panel.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Oct 13, 2010 | Proview PL926WBi 19" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
How to remove outer case on Pl926wbi
Remove the four bezel screws on the bottom edge of the monitor. Gently pry up where you removed the screws and slide the bezel off towards the top of the monitor. The six mounting screws for the lcd panel will be visible. Remove them and inplug the lcd cables and set it aside. You now have access to the main circuits.
Apr 11, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
Pedestal fixes screen tipped forward. Is there any adjustment to fix screen tipped slightly back?
most screens are on a pivitable base stand.if it falls forward or back open or remove the cover from the base stand connected to the back of the monitor and tighten the nuts at the sides.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Proview PL926Wbi
unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
Sep 30, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
283 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
