Question about DCS RGSC-305 Professional Stainless Steel Gas Kitchen Range
Just cleaned the oven,now no broil and no oven
Just cleaned the oven, now no broil and no oven heat.
ignitors do not turn on, oven heatng light does not come on.
DCS -brand
model-RGSC-305SS-L
Also where can I get a repair manual for this oven?
Thanks
  • 2 more comments
  • writetolouie Sep 09, 2009
    Self Cleaning
  • writetolouie Nov 07, 2009
    Just above the oven door you can access and remove a panel.
    There is a high temperature red reset button in that access panel.
    Evidently after an automatic cleaning it sometimes trips.
    Thanks
    Lou
    Found out there is a high temp reset button in the acess panel just above the oven door.
  • bozcro
    bozcro May 11, 2010
    did you clean by hand or self cleaning?
    Problem Solver:
  • 7 Answers
Please contact me at verng@craneengineering.com about your range.
Thanks
Posted on Nov 06, 2009
  • 867 Answers
Also sometimes the severe heating of the oven during cleaning can damage the electronics of the control panel
Posted on Sep 10, 2009
  • 512 Answers
Sounds like you have knocked the ignitor wires loose or out of position. Look at the assembly and make sure everything is connected and properly positioned.
Not sure about the manual.
Posted on Sep 09, 2009
Bake pre heat isn't working broil and top burners
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 07, 2011 | GE Ovens
Drum turns but no heat
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad.
When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner.
One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad.
Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure.
There are 50/50 chances of thermal fuse blowinf up which does not heat.Regarding the thermal fuse I would recommend to replace it one more time and not to use the Self clean any more until you will perform all checks and repairs according to the service pointer. The thermal fuse is located at the back of the oven..
You can check about the pica and description of it over HERE
And one more thing if used the broil method you also have to replace the broil heating element due to low resistance.
So finally i just want to say replace the broil element and the thermal fuse and your problem will be solved.
Goodluck,
Please don't forget to rate me as fixya..
Feb 08, 2008 | Kenmore 62602 Electric Dryer
Gas does not come on for oven to light
im assuming that your cook top works fine and that the broil is working fine. You need to replace the oven ignitor. The automatic gas valve is equipped with a sensor that opens the valve. if the ignitor doesn't heat up the sensor, then the valve will not open. replacing your ignitor should solve the problem.
Feb 06, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My broiler works but oven is not heating. Is this an ignitor problem?
That could be a good analysis---
Here is an observation you can make thru the oven door:
When you turn the oven on to BROIL-- do you see the bright glow of the ignitor?
(It is almost like a light bulb was in there-- buy the burner!)
When you start the oven (on BAKE) setting-- do you see a similar bright glowing light?
(Tho down lower, near the Lower Over Burner)
If you see the bright light-- then the ignitor is apparently heating up--
If not-- then, YES-- you are likely right--
Ignitors are fairly common failure items-- and they can obviously stop the burner from lighting-
Make sense?
Let us know if we can help further.
Mack B
Jan 15, 2011 | GE Ovens
When we turn on the oven to bake or broil, the gas flows, but the pilot light doesn't ignite.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Jan 06, 2011 | Whirlpool Kitchen Ranges
I have a Kitchenaid KGBS276X double wall oven. The botton oven works fine. The top oven will start when it's in the broil position, but as soon as I turn down the heat setting it cuts out and stops. ...
so you're saying you have no bake,correct.you have a broil ignitor and a bake ignitor,the broil only has one setting and that's broil,all the other settings are for bake.i looked up the ignitor on the sears site,it costs 189 bucks.it cross refrences to part number 12400035 and this ignitor will work and it's 62 bucks,change out the bake ignitor and you should be fine,you can check it with a meter or turn on the oven and see if the ignitor even glows,it turns red when it's on but even if it glows this doesn't mean it's good,it opens the gas valve by amps,3.5 amps but i would start with the ignitor,it should fire up in around 40 seconds or shorter,if it's more than a minute the ignitor is no good.let me know what you find,unplug the oven before you change out the ignitor
Sep 18, 2010 | KitchenAid Kitchen Ranges
I have a kenmore self cleaning gas oven. the pilots light, the broil kicks on, but preheat won't start. what can i do?
Ok well heres the deal. I'm assuming that because this is a self cleaning oven then its probably fairly new in which case you probably don't have actual pilot lights on there but "glowbars" which are called ignitors. If this is the case, and you can see your ignitors for the bake and broil both glowing then chances are you have a weak bake ignitor. If the ignitor is not getting hot enough, then it will not send enough current to the gas valve to energize it (allowing it to open and let gas in). If its not glowing at all you can just get a voltage detector (you can buy them at walmart for about 10 bucks) turn the oven on and use your wand to see if the ignitor is getting power. If it is then its going to actually be open or shorted.
Overall deal is that 95/100 times if you have a gas oven with ignitors and its not baking its and bad or weak ignitor. They cost about 60-90 bucks.
If your oven does indeed have a pilot light then you will have a bad thermocouple or possibly obstructed burner tube.
Hope this helps _MJ_
Feb 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
No broil or oven cook top works
try checking the ignitor or the thermostat in the oven.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
Oven will not heat up.
eerb, most likley your ignitor failed. When you turn the oven on to bake you should hear a relay click on the electronic control (clock). You can do a couple of things here. If you have a ohmmeter the ignitor should ohm out at between 50 and 150 ohms. You can physically swap out the bake and broil ignitors to see if the ignitor comes on in bake. Or you can swap the bake and broil wires on the board. They should be marked BA and BR. This way when you turn on bake, the broil ignitor should glow and verify you have power going to it. Carefull when testing, be sure to kill power to the range before any changes. Catriver...post back
Dec 12, 2006 | GE JGBP26 Gas Kitchen Range
DCS RGSC-305 Professional Stainless Steel Gas Kitchen Range Logo
425 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
