Question about Samsung Propel A767 Cell Phone
My propel will not get any service no matter where i go how do i fix this problem?
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Hoover self propell cable needs replacement
Hi there! We recommend taking the cleaner to a Hoover authorized service center to have the self propelled cable repaired or replaced. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jun 24, 2014 | Hoover Vacuums
My samsung propel will not let me call out, it says emergency calls only. what does that mean how do i fix it?
It means you do not have service. Check that your sim card is installed correctly. Then try it again.
Nov 08, 2010 | Samsung Propel A767 Cell Phone
Problems with my samsung propel a767
Hi friend,
I think you can cousult your GSM carrier for getting the service of GPRS or call your operators to update your GPRS, then you'll be able to send and receive MMS.The following link may be helpful for you: http://www.1010store.com/forum/viewtopic.php?f=2&t=19
Good luck!!
Aug 21, 2009 | Samsung Propel A767 Cell Phone
Self propel always engaged
you may have lost the spring that pulls the transmission drive belt down or have the cable adjuster too tight.word of caution here, the cable goes thru the engagement lever and if you overtighten it the lever will crack or break. if it does the complete transmission will have to be replaced.seems they dont make the lever avalible seperate.
Jul 09, 2009 | Troy Bilt 5.5hp Self Propelled Mower
SAMSUNG PROPEL SAYS NO SERVICE?
i work at at&t and this problem occurs frequently when the phone is dropped. Sometimes when the bottom of the phone(where the internal antenna is) is impacted with great force, by hitting the ground, the wiring where the antenna is located breaks, or is damaged. At& t store clerks can fix this problem more than likely, or if you have insurance, we can send another phone. :)
Jun 23, 2009 | Samsung Propel A767 Cell Phone
Samsung Propel - Download Message
ok had the same a767 propel for att in white
Drove me crazy that the phone was in download screen mode
So best fix and it is proven :is to open phone and disconnect small battery on mother board of the phone then leave it out for about 2 mins and leave it out
then put it back together all fixed works and powers up just fine :)
Jun 17, 2009 | Samsung Propel A767 Cell Phone
Intermittant vibration ringer
well try holding pound or thee button by the button by the camera
Jan 13, 2009 | Samsung Propel A767 Cell Phone
Samsung Propel A767 Cell Phone Logo
87 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
