Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Everything white in color has halo, cannot fix with tv menu
White halos, how do i fix it?
    Problem Solver:
  • 40 Answers
CRT FLUID REFILL....call a serviceman to do the job..its a pain in the butt
Posted on Feb 03, 2008
  • Michael Sparrow
    Michael Sparrow Feb 03, 2008
    also...you can turn down the screen control on the back of the flyback transformer and see if that helps.....
We have Phillips 55 in rear projection TV and just set our color convergence back to factory settings but we still have an awful picture. Any suggestions? All objects have multiple halo bars on them....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips 55PW9363 55" Rear Projection...
Tv shows blue halo and double image on screen
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 19, 2010 | Mitsubishi WS-55859 55" Rear Projection...
White halo around almost everything that is on the screen magnavox 64in projection
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 31, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a Philips 55pw936317f 55 inch tv that has pic problems.
Same problem here, wish I knew how to fix it... I noticed it can be helped a little if you adjust the convergence from the menu using the remote though.
Aug 29, 2009 | Philips Sport Personal CD/MP3 Player
White halo on picture
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 25, 2009 | Televison & Video
"Halo" Effect
Jan 19, 2009 | Philips Magnavox 55P9271 55" Rear...
Convergence toshiba 50a62
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Nov 20, 2008 | Apex Digital GB5108 51" Rear Projection...
Dull picture, whites have halos, need to watch tv thru dvd player
the picture color problem is the coolant in the CRTs. You can get the coolant replacemnt Kit at the following link. The other problem with the Input through DVD sounds like the signal board. You can get the replacement board and the Phillips CRT coolant kit at the following link.
http://servicemanuals.vstore.ca/
Sep 14, 2008 | Philips 60PP9202 60" Rear Projection...
Green "halo" around the bright white images
I have a Samsung HCM5535W rear projection TV that had pretty much the exact same problem-- a green halo around bright white images. I researched it on the net, and determined the most likely problem was with the convergence STK-ICs, or the convergence board. I bought a replacement board with the STK ICs and installed it, but no luck, the problem persisted. I decided to mess with the manual focus adjustment on the green crt (i was seeing a green halo), and that fixed it. As it turns out, no replacement parts were necessary to fix the problem in the first place. Hope this helps somebody out there.
Nov 14, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
