Question about Texas Instruments TI-83 Plus Calculator
When i try to graph it says error and wont let me graph
  • Texas Instru... Master
  • 8,073 Answers
Reset calculator to defaults
[2nd][MEM][7][2][2] Defaults set.
[Y=] on line Y1= enter your function then press [GRAPH]
You can draw several graphs on the same screen.
If nothing shows (except the axes) use [ZOOM] to Zoom in or zoom out or use [WINDOW] to change the values of Xmin, Xmax, Ymin, Ymax.
Hope it helps.
Hope it helps
Posted on Sep 10, 2009
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Jun 11, 2014 | Texas Instruments TI-86 Calculator
When I type in a function for y1 and have it in standard form the calculator says range Error. How do I change the range, because it wont let me go to the graph. Which is where I would then click V-window...
A linear function in standard form is of the form Ax+By+C=0, where A is a positive integer, B and C are integers (positive or negative).
The problem is that calculators graph a function given in functional form y= ax+b.Thus to graph a function in standard form by means of a graphing utility you must isolate the y variable. The interesting thing about the Prizm (Casio graphing calculator) is that you select which variable to isolate y (usually) or x if you so choose. To choose to graph the function x=Dy+E you must select the function type as X=.
Sep 15, 2013 | Casio FX-9860G Graphic Calculator
My ti-83 plus calculator wont graph
What does it do when you try to graph? Is there an error message?
Aug 05, 2013 | Texas Instruments TI-83 Plus Calculator
Error: Invalid
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Mar 27, 2012 | Texas Instruments TI-84 Plus Calculator
Error message invalid dimensions
INVALID DIM error message may occur if you are trying to graph
a function that does not involve the stat plot features. The error can be
corrected by turning off the stat plots. To turn the stat plots off, press
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
When I graph it gives me an error of "invalid
If this doesn't do it, could you post the function you're trying to graph?
Oct 12, 2011 | Texas Instruments TI-84 Plus Calculator
My graph looks bigger than normal
try reseting ur calc. press 2nd->plus button->7->1->2 and then type the problem again
Jan 15, 2009 | Texas Instruments TI-83 Plus Calculator
Dimenssion error when trying to graph a function
Dec 14, 2008 | Texas Instruments TI-83 Plus Calculator
Graphing
You're probably trying to graph a function that does not involve stat plot features and thus getting a dimension error. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Aug 29, 2008 | Texas Instruments TI-84 Plus Calculator
Error in graph
...with this process you will erase everything....
press "2nd" function and then "Mem"
then press "F1" and choose "3"
Press ok, and then wait, THAT'S IT!
May 20, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
