Question about Whirlpool GBD277PD Electric Double Oven
Oven gives code E6 F2 on panel
Our electric double oven, which is 4 yrs old (model #GBD277PD509) stopped working last Saturday (it was not being used when it went down) and, every 6-8 hours or so, displays a code of E6 F2. (If the code isn't displayed, the panel is blank.) Do you have any ideas of what has happened and how do we fix it?
  • 4 more comments
  • Teena217 Dec 15, 2007
    I have the same problem. My oven is also about 5 y/o and have recently begun to have the same E6 display. I flipped my breaker to the oven, which made it reset itself. But it has done this several times, so need to find a solution to the problem. Any ideas? I called the 800 number for Whirlpool and they could not seem to answer my question or give solution.
    Thanks. CBC
  • Anonymous Dec 30, 2007
    I have the same oven, same problem. My oven would display the E6 F2 error code. I contacted the local repair company. First question, did you use the self cleaning cycle? Yes. They told me the oven puts out so much heat during this operation the control panel will over heat and short out and has to be replaced. Several hundred dollars and four months later the part finally arrives and it the control panel replaced. Three days later I am dealing with the same issue and I used the oven once - baked brownies. So I have since removed the control panel, cleaned the contact ribbon leads, reinstalled the board with the same problem existing, a few beeps and no display. The oven seams to turn on and will flash a preheating timed message but that is it. Whirlpool is useless in any effort to help in the solution. Anyone out there with any ideas. Thanks
  • m204prgmr Jan 12, 2008
    Brecksville OH
    We have the same oven and this is the first time we've experienced a blank display panel. Last week we used the self-clean oven but it wasn't the first time for using it and the oven has been in use since.. There is no code on the display, just black blank..:(
  • Tiffern Feb 06, 2008
    I also have a Whirlpool Gold Double convection ove, model # GBD277PDB7. I am experiencing an error code E0 F2. First time it happened was after a self cleaning and seemed to remedy itself after a couple of days. This past weekend I made hot wings in the oven at 500 degrees and after about 45 minutes the oven flashed the error message and shut off. The oven remains inoperable at this time with the same error message. Our oven is about 4 1/2 years old. What a shame if this will continue to occur over and over. We have been looking at the LG model.
  • Anonymous Aug 13, 2008
    my double oven panel went blank except the light will work. Codes e6 andf 2 appeared and the oven came back on for a brief period of time and now it is dead again. Please help me locate the problem. I cannot find my manual and the ovens are 4 years old
  • Gary Davd
    Gary Davd May 11, 2010
    On the model # there is a letter and a number after the "D" i need that inorder to help you
The problem in our oven has cleared by itself. I did see the E6 F2 error message but for now, it's working fine. Considering the customer service was only able to help to the extent of reading the error code sheet the same as I was (the sheet is behind the touch pad) and seeing how limited the solutions were, we don't think we'll be buying another Whirlpool. I was pretty insulted when the girl a customer quality called to offer me part #8300453 at half cost of $164 providing I have a service guy look at the stove and call in the part. On top of that, the warrenty is 90 days and the part is on back order. Why would the part be on back order? A) they either did not make an ample supply for inventory, B) there are many ovens needing this part. For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me someone was sleeping with a cigar in their mouth in Quality Control. Or, learning what that meant.
Enjoy the day!
Robert
Posted on Jan 26, 2008
  • 770 Answers
Until i get a Complete Model nuber here is was i found on the fault codes .....No E6
CODE
NATION
RECOMMENDED REPAIR PROCEDURE
F0 E0 Default F code
-no failure
Will only be displayed if user presses and holds CANCEL key for 5 seconds and there
is no pre-existing fault. Press CANCEL again to clear display.
F1
E3
Wiring harness cavity
size does not match
previously stored value
The “Cavity Size Select” jumpers in the wiring harness indicate a cavity size different
from that which the control was previously configured for. Check the jumpers in the
harness to make sure they agree with the actual oven size.
All Other
E Codes
Electronic control
malfunction Replace control if the E code is not E3.
F2
E2 Keypad not connected
1. Check keypad connector for firm connection.
E3 Key held down too 2. Press CANCEL. If error code returns after 60 sec., replace keypad.
long, or key is shorted
F3
E0 Temperature sensor
opened
1. Check sensor connection.
2. Measure sensor resistance (1080W at 70° F. Add 2W per degree.)
3. If resistance is not valid, replace sensor.
4. If sensor resistance and connections are good, then the oven cavity temperature
must have exceeded a safe level. Check for welded-closed relays on the control.
E1 Temperature sensor
shorted
F5
E1 Self-clean latch will not
lock
1. Check the latch assembly: latch arm pivot joint, arm/solenoid connection, solenoid
spring, and spring washer.
2. Check the Latch Solenoid:
- Check for firm electrical connections.
- Disconnect the two wires from the solenoid and measure the resistance of the
solenoid. A small resistance (approx. 175W) is normal. If the solenoid is open
(¥W) or shorted (0W), it should be replaced.
3. Check the Latch Switch. Disconnect it and use a continuity tester:
- Door latched = switch closed, continuity should read 0W.
- Door unlatched = switch open, continuity should read ¥W.
4. Check Door Open/Closed Switch. Disconnect it and use a continuity tester:
- Door open = switch closed, continuity should read 0W.
- Door closed = switch open, continuity should read ¥W.
E6 Door is open, but latch
is locked
E7 Self-clean latch will not
unlock
F7 E1 Common switch wire is
defective
Common wire (+5VDC) to latch switch, and to door switch is shorted to chassis ground
or neutral. A double oven will have two of each switch and one common wire.
1. Check connections at control and at the latch switch and door switch.
2. If all connections are good, then check the individual switches as outlined for the F5
failure.
FAILURE/ERROR DISPLAY CODES
Electrical Shock Hazard
Disconnect power before servicing.
Replace all panels before operating.
Failure to do so can result in death
or electrical shock.
I have Whirlpool dble oven GBD277PDS09. Everything works perfectly except the oven lights (upper & lower). They don't come on when the door is opened nor do they come on when the "light" button is pressed. Are the lights wired so they won't work if any of the bulbs are dead or is there another problem?
Posted on May 22, 2010
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
i have you a tech sheet for you accept this soultion and e mail me at b4829@yahoo.com so i can send it to you just reference code f2 e6
May 24, 2008 | Whirlpool GBD277PD Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
WHIRLPOOL GOLD DOUBLE OVEN BEEPING WILL GO BLANK THEN WILL SHOW E6 F2 TROUBLE CODE
Hi dear.Please do the following if you know what you are doing.According to your explanation,F2E6 code on whirlpool oven related with following: F2 - E6
I hope that solves your issue.Thanks.
Aug 28, 2010 | Whirlpool GBD307PDS Electric Double Oven
I have a whirlpool oven rbs305 and the pannel shuts down and a code comes up E6 and F2 What can be done Thanks
F2 and e6 in combination indicate a cancel key open condition. What this means in layman's terms is that the key-panel Has a problem. If it was just recently cleaned with a wet cleaner, you can try drying the keypad off or even CAREFULLY warming it up with a hair dryer. Don't get it too hot so that you melt anything.
If this does not work, you will need to replace the key panel on the oven.
You can do this repair yourself and should you decide to, please just comment back with the full model number off the tag on the oven and I will give you step by step instructions on how to do it.
Good luck!!
Aug 14, 2010 | Whirlpool RBD305PD Electric Double Oven
F2 error code
F2 E6 says this:
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool GBD277PD Electric Double Oven Logo
1,688 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
