Question about HP Photosmart C6180 All-In-One InkJet Printer
I have the same problem
Printer starts up, then powers down and starts up again.
  • 555 Answers
This usually happen when the power supply goes bad or there is a short circuit in the printer. Perhaps a jammed motor.
Posted on Sep 09, 2009
Canon Pixma MG6650 waste ink absorber full
hi, you have to remove/or replace the ink absorber pads, or perhaps wash them out. the printer then needs a reset.ie hold in power button to turn off, then hold in power button and keep holding in until printer starts and then turns off. that should reset it(clear any registered faults). it should now start ok.
Nov 09, 2017 | Canon Office Equipment & Supplies
How do I fix a Canon MG5220 printer with 6C10 code. I cleaned the waste ink but cannot get printer to start all the way before it sets the code
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Reset Canon Printer ink absorber ..this is all i can find.
Dec 03, 2016 | Canon Office Equipment & Supplies
Bc sensor error
Bar code read error: The printer does not detect the presence of the ribbon bar code sensor
1. Power down the printer. Remove the ribbon and wipe the two lenses of the ribbon bar code sensor with a lint-free cloth or cotton swab.
2. Install the ribbon and power on the printer. If the message appears again, replace the ribbon.
3. Power on the printer. If the message appears again, power down the printer and remove the paper path or top cover to gain access to the card cage. Make sure the cable from the ribbon bar code sensor to connector J122 on the controller board is undamaged and has a good connection to J122.
4. Power on the printer. If the message appears again, power down the printer and replace the ribbon bar code sensor.
5. Power on the printer. If the message appears again, power down the printer and replace the controller board. Record the message and return it with the defective board.
I have the parts in stock if needed cardenas_rory@hotmail.com
May 06, 2014 | Printronix P7005 Matrix Printer
The ink system not working
here. try to reset your printer. this will clear annoying error displayed on your printer
1. Remove all cables
2. Unplug the printer power.
3. Press and Hold down # and 6 on the keyboard.
4. Plug the power cord back in.
5. Then release the buttons....after successful boot operation, try to print.
If that did not work.. you can also try this.
1. Press/Hold down the HELP and OK button..then unplug printer..release the button
2 Press/Hold down the HELP and OK button again..then plug the printer back in. Just Press and hold down the button while you wait for the printer to turn on (it could take a minute)
3 Now release the buttons and power it back on.
4 Error message will be displayed “improper shut down”
5 Press OK to reset the printer
6. Press both HELP and OK button again to start the resetting procedure of the printer.
Now try printing again...
If you find this very helpful..please rate this solution and vote on this on the YES below....thanks..
Jun 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart C6180 All in one printer will not start although live
Strange because I have the same issue, and I've had this printer for over 3 years but the problem just started about a month ago.
I reset the printer by: 1) Unplug power to the printer 2) Hold #6 on the keyboard 3) Plug power cord back in while holding #6 Eventually (10 seconds?) the printer will shut down. Once it does, release #6 and power up the printer again.
Warning: This reset all the configuration settings.
This works for me, but there is still an issue because I have to repeat this every time I turn off/on the printer.
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Won't switch off
Having taken the printer apart to check all connections, etc, I put it all back together but the problem persisted. I eventually solved it by holding down the On/Resume button and then plugging in the power lead. The printer started, I was able to shut it down normally, remove the power lead, then start it up again in the usual way ie. without having to hold down the On/Resume button before plugging in the power lead. I can only assume that some sort of "glitch" occurred when it was originally turned off.
Feb 06, 2010 | HP PSC 1350 All-In-One Thermal Printer
Printer will not stop printing
Shut down your operating system (in windows, start, shutdown...) If while the computer is off the printer continues to print then power down the printer. You should be able to hold down the power button if it doesn't power off right away. If that doesnt work you can pull the power plug on it as a last resort. Leave it disconnected, boot into windows, go into control panel (start, control panel) go to printers, double click on the printer in question and verify there are no print jobs attempting to print. Let me know what you find =).
Jun 25, 2009 | Lexmark X73 All-In-One InkJet Printer
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Print
hmmm..ok..power down completely..
unhook from computer
press button on power panel down..hold it for ten seconds, while plugging in power cable again..
system should go through start up sequence
then try a test page..
if not , time for factory service.
Aug 06, 2008 | HP DeskJet 1280 InkJet Printer
My laserjet 1300 burnt
b'coz of your printer power supply goes to down
replace powersupply unit
Feb 27, 2008 | HP LaserJet 1300 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
