Question about PfaFF Creative 7570
The bobbin How do I wind the bobbin and thread the machine?
  • 201 Answers
You need to turn the wheel inside the handwheel to wind a bobbin. You will feel it "release". (I think you turn it towards you - can't remember, sorry!) Don't forget to turn it back when you are done.
Posted on Dec 22, 2007
Bobbin not not threading, what's the problem?
We don't know the make & model of your machine. Are you trying to wind the thread onto the bobbin?
FWIW, for ~$30 there is a stand-alone bobbin winder called "Sidewinder" that can be used to wind all your bobbins. It saves wear-n-tear on your machine and you can wind bobbins without removing the thread from your sewing machine. Just be sure to verify that your bobbins are compatible with the Sidewinder.
Available at JoAnn's, Walmart, Amazon...
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jul 19, 2017 | Sewing Machines
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
Not catching to wind the bobbin
you have to hold the loose end for a few seconds .
Mar 20, 2016 | Sewing Machines
Trying to wind the bobbin on my Pfaff hobby 1132. The thread keeps coming off the bobbin thread guide. The bobbin winds, but the thread is loose and uneven. I've pushed the bobbin holder to the right and...
Check to make sure the thread path from the spool to the bobbin is correct. The thread should make a loop around a little post that is actually a tensioner that helps the thread wind smoothly onto the bobbin. If something is wrong with that tensioner or the thread is not following the correct thread path, it could cause the thread to not wind smoothly. It appears that your machine has two locations where the spool can be placed to wind the bobbin. You might try using the other option, if one doesn't seem to be working.
Also, you might try slowing the machine down during the thread winding process. It it goes too fast the spool begins bouncing and pulls the thread akilter. Also, some threads will stretch if the winding is too fast causing the thread to "shrink" when sewing your garment and creating puckers.
FWIW, I found that a "SideWinder" stand-alone bobbin winder is a handy gadget. It is available for ~$30 from JoAnn's Fabrics, Amazon, etc and is battery or electric compatible. It saves wear and tear on a machine and can wind multiple bobbins one right after another. Just be sure to verify that your bobbins will work on the SideWinder as some Singer bobbins will not.
Nov 16, 2017 | Sewing Machines
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
Bobbin
To insert a filled bobbin, lift the presser foot and turn the hand wheel to put the needle at the highest point. Slide open the face plate and drop in the bobbin with the two holes up. Pull the thread into the groove near the center front of the bobbin opening and then to the left (another groove). Then pull it to the back of the machine and close the face plate.
To wind a bobbin, you will need to unthread the machine most of the way. Leave the the thread through first and second thread guides. Then bring the thread around the bobbin winding disc (so that it goes under and around the disc) back towards the bobbin pin (on the top right of the machine). Pull the thread through the correct hole in the bobbin (the one away from the center of the bobbin). Leave a 4" tail. Push the bobbin onto the pin and then push the bobbin and pin as far to the right as it will go. Hold onto the thread tail and step on the presser foot to start winding. After ~10 winds, temporarily stop winding and cut the thread tail. Then step on the presser foot and complete winding. When done, cut the thread to separate the bobbin from the top thread. Rethread the top thread and insert your bobbin.
The manual for the 4228 is available here: http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf . See page 31 (18 of the pdf) for pictures of threading and winding the bobbin.
I hope this helps.
Jan 19, 2012 | Singer Inspiration 4228 Mechanical Sewing...
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin won't wind correctly!!
Iam very picky about my bobbins!
make sure you are threading the machine for the bobbin correctly, In my opinion I don't think any machine really winds well.
What I do is hold the thread about an 1" away from the bobbin. start to wind and I guide the thread slowly up and down the bobbin so that it winds even
Aug 28, 2009 | White Sewing 2200 Multi-Tasker
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Sewing Machines Logo
234 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
