Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My brake is hanging up,causing reverse and forward motion to be very slow I can pull the pedal up by hand and it operates good. This on a john deere riding mower model LX 255
  • 10,515 Answers
The first thing I want you to do is cut the filter apart, remove a few of the pleats and squeeze them in a vise. You will be looking for fine black material, and anything else . Also, did you remove the transmission suction screen and clean it?
I believe the screen is located on the lower right rear corner of the case, a cover with three bolts holds it in place.. You will have to drain the transmission to remove the screen. There isn't much that can go wrong in the syncro-range other than bearing problems, unlike the power shift which can get clutch slippage within the clutch packs. Its possible one of the oil tubes has broken within the transmission in turn causing one(or more) of the bearings to be not receiving lubrication.
Also, if you can, clean off the rear of the transmission housing, if the paint is discolored, this would indicate that the brake behind the rear-most housing is hanging up. If the machine is still pulling good I would not suspect clutch slippage as the problem. The brake housing will need to be removed and disassembled, thoroughly disassemble the components in the housing, paying close attention to how things are assembled. When you get the parts, ask your dealer to print you off a picture of the parts listing for the brake housing, this will aid in re-assembly. When apart, be sure to not skimp on what parts you replace, if the disk shows discoloration/scoring it will need to be replaced as well as the brake pads. Verify that the linkages going to the brake lever are not bent, hung or other wise malfunctioning. Also, this would be a good time to remove the floor plates and clean any accumulated debris out (sticks, leaves....).
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 09, 2009
John deere 3320 error code 03
Err 03 Reverse Pedal. Voltage signal out-of-range or not calibrated. Machine does not drive. Contact your John Deere dealer.
Oct 14, 2015 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere 826 will not go forward or reverse
Can anyone help me with a john deer 826 snow blower that won't engage in forward motion?
Mar 04, 2013 | John Deere Mowers Tillers Snow Blowers...
I have a John Deere LT155. When you let off of either the forward or reverse pedal the tractor comes to an abrupt stop. It will actually lock the wheels.
Hi, most likely the brakes are hanging up. Follow the brake pedal path to the rear of the mower, it is attached to a small arm on the side of the diff that is probably locked forward. This lever and the pins behind it need to be freed up so the lever operates forward and backward freely when the brakes are applied and released. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere 22HP VTwin Hydrostatic 42"...
Brake pedal won't release on a John Deere 316 lawn tractor
I have the same problem. I just wiggle the black handle on the parking brake release. It usually allows the pedal to come back up. One of these days I'll see what hanging up in the linkage.
May 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Peg Perego John Deere tractor 12volt will only work in reverse. Will not go forward in the slow or fast speeds
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Aug 16, 2009 | Peg Perego John Deere Turf Tractor
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
42 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
