Question about Compaq Presario R3000 Notebook
Both fans on my presario laptop wont run can I buy replacements? Thank you!
    Sergeant:
    Champion:
  • 249 Answers
Yes
Posted on Sep 09, 2009
I have a compaq c60 laptop. a couple days ago the laptop would turn itself off and when i would to reboot it, it would only last a couple of seconds. i noticed its really hot right above and below the fan...
Hello, well, if the fan is stalled, then it really needs to be replaced as it will still be consuming power and getting HOT...which is really not good for a laptop as there is little natural air flow within the case anyway. Actually, I've seen those sort of laptrays with a built-in fan, and I think they're a really good thing to have, bearing in mind if you're running the laptop on battery then it'll drain the battery quicker! But have one IN ADDITION to a normall fully-functioning laptop, not as a substitute for a failed internal fan. I advise get that fan replaced asap before you cook something vital (and expensive) in the laptop. Kind regards, nicam49
Jul 08, 2011 | Compaq Presario Fan
Compaq presario laptop cq50 110em ///over heats and switches off ..however fan works fine .. dosnt make sense to me the laptop only gets hot in one particular part exactly where the fan is
If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 28, 2010 | HP Compaq Presario CQ50-110US Laptop
When ipower on my compaq presario x1000 laptop the power light goes on and the fan spins for a few seconds and thats it .once in a great while it starts up fine but very rarely.any sugestions? thank you
Hello.
I suspect that your systems may be overheating and shuts itself off.
Disconnect all power. Remove covers as needed.
Some suggestions are:
1. Reseat the memory
2. Remove the bottom of your laptop where the fan is located and blow out all the dust with compressed air.
3. Replace the fan
4. If you wiggle the power cable near the laptop and the laptop works for a bit, your power jack may need to be soldered or replaced.
Hope this helps.
Nov 12, 2009 | Compaq Presario Notebook
Compaq Presario fan is not functioning. It is - fan is plugged into the motherboard but the fan will not run - causing my laptop to overheat - I cannot find a fan controlling software that is compatible...
sounds like a burnt up fan so you might just want to take it to your local computer tech have them replace the fan and put some new cpu compound in their and it will never over heat again
Aug 06, 2009 | Compaq Presario Fan
Broken fan on compaq
don't keep running it until you replace the fan. Look for one on ebay or around the web. It is shutting down because of heat. A $20 fan could cost you your whole laptop if you keep running it.
Jun 03, 2009 | HP Compaq Presario CQ50-110US Laptop
Wont Turn on, Monitor Flashes a bit
oops, I did see the model on your Presario.
This sounds like it could be the motherboard or power circuitry.
If the DC jack was replaced, and the AC adapter, I would say the motheboard is bad. I have seen this on many models, not just the Hps.
If your laptop is under warranty, I would definately contact HP. If you have a local repair shop, that is probably your next best bet.
Mar 26, 2009 | HP Compaq Presario C502US Notebook
Noisy fan on a Compaq laptop Presario 2500.
Have you tried following the instruction in the Service Manual(pdf) published by HP online?
Nov 30, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Loud Fan on my Laptop
Here is one for $28 plus shipping.
http://cgi.ebay.com/Compaq-Presario-C500-CPU-Cooling-Fan-409073-001_W0QQitemZ290267492182QQcmdZViewItem?_trksid=p3286.m20.l1116
Oct 16, 2008 | HP Compaq Presario C500t Notebook
Laptop wont power up.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Good Luck, Read and folow instructions/Please dont for get to Vote/Thank You.
Dec 25, 2007 | Compaq Presario R3000 Notebook
Display off center
Laptops are very hard to work with and are very fragile. You can tinker with the connection and get it to work better but I would suggest that you just buy another monitor for it and replace it. Once the ribbon is broke there is not much you can do.
Dec 04, 2007 | Compaq Presario 12XL125 Notebook
Compaq Presario R3000 Notebook Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
