Question about RIM BlackBerry Storm 9530 Smartphone
My storm battery icon was yellow then went to all red. I have it turned off and charging right now and indicator light is blinking greenish red? Is there a problem or does it just need charged
    Scholar:
  • 88 Answers
Battery icon goes yellow when charge is low, red when about to go off, yes, that's OK. Recommend give it more time after all the bars are full-white, to trickle more into the battery. Lithium batteries don't seem to like being flattenend and left flat in my experience.
The light blinks for all sorts of things, might also have pending messages, etc. Can use the Storm OK while it's charging, just hold down red button to turn it on again.
After turning on, sometimes the cellular receiver does not turn on until battery is more charged. Wait 10 mins and then try to make a phone call, you may get a message saying it's off, do you want to turn the receiver on - just say yes.
That should keep you going. Nice phone.
Posted on Sep 12, 2009
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
Mydell 5160 has a yellow blinking light on the front 1st from right. any suggestion on cause or solutions.
It is the battery Status indicator and flasing orange light indicates that battery is low. After connecting the charger it should turn solid green, which indicates that the battery is charging and it turns off when battery is charged completely.
If it continously blinks, check out the charger and battery.
Dell 5610 owner's manual can be downloaded from:
http://support.dell.com/support/edocs/systems/ins5160/en/OM/G74822LRs.pdf
Check out Page-15
Let me know if any clarification is required
CreativeTECH
Nov 12, 2010 | Dell Inspiron 5160 Notebook
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Vivicam 8300s
I've been struggling with the same problem and could not figure out what the heck was goin on. When I would connect the camera to the charger the red light (indicating charging) would come on for like maybe 10 minutes. I could take pics for like 30 minutes then the camera would lose juice. Also, the green battery icon (indicating a full charge) would only stay green for like 1 minute then it would go right to the yellow battery icon (half charge). After a couple of weeks the red light indicater would only come on for like a second. I played around with mine and realized that the battery terminals were not connecting to the power source inside the battery holder. Basically the battery wasn't snug enough inside the battery holder to connect to the power. When I pushe the battery in with my finger the red light indicater would stay on. So I took a little piece of paper (folded slightly) and wedge it in the battery holder and closed the battery holder cover. Hope this makes sense! (And helps.)
Feb 28, 2009 | Vivitar ViviCam 8300s Digital Camera
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
Acer laptop
If the machine works properly with no problems, it's probably the battery light, indicating that the battery is no longer working properly, ie.. not charging, not holding a charge, not charging completely, etc... and needs replacing. Somewhere right around the light there should be an icon or symbol, I'm betting a little battery icon.
Jul 08, 2008 | Acer Aspire 3003WLCi Notebook
Battery indicator light blinks red
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
Apr 28, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry Storm 9530 Smartphone Logo
259 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
