well that's basically it. the pump is humming as if it's working, but it doesn't drain. It's been working flawlessly for 5 years now, and I haven't moved it around, so it shouldn't be the hose? I've read maybe I can push two buttons, and the system will reset, I just don't know what two buttons? I hope you can help.
My Siemens SL84A305UC/26 dishwasher will not drain. I've checked the drain and it is clear. I can...
(More)
My Siemens SL84A305UC/26 dishwasher will not drain. I've checked the drain and it is clear. I can hear the motor hum during the drain cycle. It will fill and wash OK, but not drain. Does this machine have a solenoid for draining and if so how do I check it? How do I check the pump to ensure it is functioning correctly? I've tried to remove the plastic bottom of the machine to see what is inside and to troubleshoot the components, but it seems almost impossible to remove. What is the trick? What and how should I troubleshoot the machine?
My Siemens SL84A305UC/21 dishwasher will not drain. I've checked the drain and it is clear. I can...
(More)
My Siemens SL84A305UC/21 dishwasher will not drain. I've checked the drain and it is clear. I can hear the motor hum during the drain cycle. It will fill and wash OK, but not drain. Does this machine have a solenoid for draining and if so how do I check it? How do I check the pump to ensure it is functioning correctly? I've tried to remove the plastic bottom of the machine to see what is inside and to troubleshoot the components, but it seems almost impossible to remove. What is the trick? What and how should I troubleshoot the machine?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
