Question about Tomtom ONE GPS Receiver
Using tomtom without lighter adapter
My car lighter does not work
    Scholar:
  • 143 Answers
Look into it & see if anything has got stuck in it...
If there is somthing in there remove it with plastic or wooden tweezers.
find your cars user manual & find the section on fuses, find out the position of the fuse box, the position of the cigar lighter fuse & its rating.
if it is blown replace it.
After this if you still have no joy, buy one on a long lead,
connect the cables to the battery using a fuse holder with a appropriate fuse.
Posted on Dec 16, 2007
Can i use tomtom in 1996 ford mondeo cigarette lighter
So long as it is a 12 volt negative ground system then yes. Plug ins are designed for cigarrette lighters in cars.
Nov 24, 2013 | Tomtom GPS
How can I charge my Tomtom GPS 550 at home using a USB to my PC ? Or can it be charged only in the Car using the Car Charger ? How long should it take to fully charge using USB & also on Car Charger ?...
i dont believe it can chagre via usb as usb only provides up to 5v of power you can buy from walmart a cheap ac to car adapter (makes your ac outlet a cig lighter adapter) and power it that way.
Mar 27, 2011 | Tomtom XXL 550 Car GPS Receiver
The Tomtom XXL was unplugged from the cigarette lighter overnight. What do I do to recharge it?
The device can be run from the lighter plug without being charged first. The obvious answer is: plug in the device again; when the car is key is in and electricity switched on, it should charge again.
Most Tomtom devices also come with a standard USB cable or charge cradle with non-standard connector on device end (but USB on the other). It plugs in a PC for use with the Tomtom HOME software and also for charging.
Jan 01, 2011 | Tomtom GO GPS Receiver
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
Have tom tom for car,need to wire it up to m/cycle
I've wired my tom tom for use on a motor bike.
you CANT run 12v straight into the tomtom, you can see on the cig lighter plug it has a 5v output.
So I bought cheap lighter socket, it looks like plastic tube with the cable running out of the back.
So the wires run from the battery (via an in line fuse) to the cig adaptors, these are hidden in my side luggage bag to keep dry and up to the tomtom. job done
Apr 20, 2009 | Tomtom ONE 3rd Edition GPS
Tottom direct power supply
No, it will fry the unit!!!
You need the cigarette lighter adapter to bring the voltage down to 5V. More than 5V will fry the One.
Apr 02, 2009 | Tomtom ONE 3rd Edition GPS
HAVE NO LIGHTER THAT WILL ACCEPT NEW PLUGS
there are ways u can charge your gps 1 is to buy extension for your lighter i know that the plug is very big adapter is about 6.00 to 15.00 dollars.
also battery life after full charge is about 45 min not long at all
your lap to will charge it
ha hope u and your tom tom are very happy
ps keep it pro k bye bye get it
Dec 17, 2008 | Tomtom ONE GPS Receiver
Tomtom 910
hold the on button (top left skinny button) for 2 seconds. And if that doesn't work, use a TINY pin to reset the unit.
Jan 12, 2008 | Tomtom GO 910 GPS Receiver
How do I recharge my Tom Tom One?
I talked to TomTom support about recharging. They say that the unit uses more power than it gets, but if you turn the power off while the car is running, it will recharge.
Aug 28, 2007 | Tomtom ONE GPS Receiver
Tomtom troubleshooting
My daughter had this problem and it actually turned out to be the cigarette lighter connection. The fuse needed changing and bingo all working well now! Check you have a green light on the charger cable going into your cigarette lighter - if you dont its probably the fuse.
Aug 01, 2007 | Tomtom GO 700 GPS Receiver
Tomtom ONE GPS Receiver Logo
98 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
