Question about Emerson Microwave Ovens
Buttons 1,2,3,4 & 5 not working - Emerson Microwave Ovens
  • Emerson Master
  • 9,098 Answers
You have a failed membrane keypad.
Posted on Sep 11, 2009
Samsung microwave model # ME21M706BAS/AC How to set the clock
1. Press the Options button.
2. Press the 9 button.
3. Press the OK button.
4. Use the numeric buttons to enter the current time. You need to press at least three numbers to set the clock. For example, if the current time is 5:00, press 5, 0, 0. The display will show 5 : 00.
5. Press the OK button.
Here is a link to download the user manual:
http://downloadcenter.samsung.com/content/UM/201712/20171229143437765/2017.12.22_ME21M706BA_AA_EN-MES-CFR.pdf
Feb 09, 2018 | Samsung Microwave Ovens
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
How to unlock the samsung microwave
Setting the Child Protection Lock
You can lock your microwave oven so it can't be used by unsupervised
children.
1 Press the My Choice Button and the 5 button at the same time for
3 seconds.
The display shows : CHILD LOCK ON.
2 The display returns to the time of day.
At this point, the microwave oven cannot be used until it is unlocked. To
unlock it, repeat steps 1-2 above.
May 19, 2014 | Samsung SMH7178STD Microwave Oven
Control panel not working
If you can open up, try to clean the ribbon connector.
My oven was sending "1" all the time, filled the memory and caused permanent beeping! I wanted to cut off the "1" connection but after opening I found that the panel was diffuclt to disassemble. I just cleaned the ribbon connector and put it pack. It needed a few attempts to get it to work all the buttons properly. But then it has been working for more than year without problem!
Aug 26, 2013 | Hotpoint Microwave Ovens
Hotpoint microwave key pad parcially not working
The pads actually share some of the same lines inside the touch pad. There are silver oxide traces inside there. If a trace inside breaks, it depends on which trace breaks as to what pads dont work. If a trace that is common to say pads 1,3,5,7 you would lose function of those pads. 1.....2.....3.....4......5....... it is sort of set up like that inside wher eone connects to another and so on. So lets say a line between 2 and 3 breaks then you would lose pads 3, 4, 5 and any others on that same line. Will have to replace touch pad, cannot repair.
Oct 15, 2017 | Hotpoint JE740WY/GY Microwave Oven
How do I fix the programmed buttons 1 - 5, they stopped working? We can only use the 6 and above numbers.
You must dismantle the circuit board and check if some grease vapours between touch buttons and the the circuit film. Clean with some wet soft cloth.
Nov 13, 2017 | Whirlpool MH3184XP Microwave Oven
Work out how long my battery will last using a
Your said your battery is rated for 85 amps / hour. This means 1 hour at 85 amps, 42 hours at 2 amps, 85 hours at 1 amp or any number of hours in between determined by 85 divided by the number of amps of the load connected. The microwave uses 600 watts. Since we can't reliably determine amps in an AC circuit - I can get close using the DC calculation. I'll assume 120 Volts at 600 watts for the microwave. Watts = Volts multiplied by Amps, so the microwave uses about 5 amps (120 x 5 = 600). HOWEVER, this is not an accurate way to determine AC amps when voltage and watts are known. I'll bet the microwave has the actual amount of amps (along with the model, voltage, wattage etc.) on a label on the back, side or inside the door. This is the information that is accurate. Use the amp rating provided on the name plate to determine how long the batter will last. Assume 8.5 amps is the value provided on the name plate.. 85 amp hour (85 AH) battery would supply an 8.5 amp (8.5 A) load for 10 hours because: 85 AH divided by 8.5 A = 10 H. The quality of the battery, and the losses contributed by the inverter will reduce the actual amount of time that the battery could supply the microwave.
I hope this helps!
Sep 18, 2009 | Panasonic Microwave Ovens
PUSH A BUTTON & PRAY
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Jun 06, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
32 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
