Question about Ricoh Aficio 450 Copier
Paper jam E light won't reset in Ricoh A423
The machine has an 'E' error code which signifies a paper jam in the bottom tray. I check and there's no paper jam and replaced the paper in the tray. However, the 'E' error code stays on. I tried blowing compress air around the rollers thinking something might be stuck there but no luck. Any suggestions.
  • 1 more comment
  • chess4fun Dec 10, 2007
    Wrong model number. It's Ricoh 4727. Thanks.
  • chess4fun Dec 11, 2007
    I'll try that on Friday when I'm back to work. Will post back to let you know. Thanks.
  • chess4fun Dec 15, 2007
    Hi jules_09,
    Any suggestions where to look for the sensor? Thanks.
    Al
  • 69 Answers
Hi im jules_09,look for thr microswitch or sensor in the tray try cleaning it with alcohol just soak with alcohol if that doesnt work replace the sensor or microswitch
Posted on Dec 11, 2007
After replacing fuser upper roller machine shows error code 010-327.after resetting 3 to 4 times then the machine comes in ready
That error signifies that the fuser is not heating up, it could be the lamp or the thermistor, check your connections and lamp continuity.
Jan 19, 2016 | Xerox Workcentre 5225 / Copier, With...
My Machine MPC 2030 is showing continiously paper jam in A after the machine is powered on. Physically no paper is there.
Remove the paper from the paper tray and reset the jam by opening the right hand side door. If the machine turns over, replace the paper in the tray and check that the guides, in particular the green guide, is nice and tight around the paper.
Oct 18, 2013 | Ricoh Office Equipment & Supplies
How do you reset an H5-01 error code on Sharp Color MX2300 Copier.
Hello
Most error codes can be cleared by removing the paper jam and then rebooting the machine. When an error code occurs, make a note of the code and then follow the instructions on the control panel for clearing it.
Paper jams can be caused by a variety of issues in the copy machine, but jamming can commonly be caused by improperly loaded paper in the trays or dirty paper feed rollers.
If you get repeated paper jams, remove the paper from the trays and inspect the stack. Look for folded corners, especially on the bottom of the stack. Fan the paper thoroughly and then reload the stack into the tray. Check the paper guides to ensure they are not too tight or too loose. Both conditions can cause paper jams.
If you can see the paper transport rollers by opening the ordinary access covers and panels inside the machine, cleaning them might help reduce paper jams. Shut the machine off and unplug it, then take a soft, lint-free cloth dampened with water and wipe those rollers off. A buildup of toner and paper dust can cause them to slip while transporting the paper.
Oct 21, 2010 | Office Equipment & Supplies
Ricoh 2018d light stays red
Hi, the red light will generally stay lit for one of four conditions: if there is no paper in the trays, if the copier is out of toner, if there is a paper jam, or if there is an error code. The specific condition should be displayed on the operation panel. Do you see a message or error code?
Oct 19, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh error code 741
Hi
SC741 means 1,000-sheet Finisher Error in Saddle. You'll need to check the Stitching Area, Optional Paper Tray Unit. If the tray unit is fine then check the stitching area as well for any paper stuck or bits of paper If there is no paper then it is due to LCT Main Motor Error. You'll need to check the LCT motor whether it is jammed or not. Hope this helps...
Daniel
Sep 30, 2010 | Ricoh Office Equipment & Supplies
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Have a ricoh aficio 450 and there is error code sc 623?
1. With the machine turned off. Go to the back of the machine and disconnect the cable that goes to the paper deck.
2. Turn on machine.
3. Turn off machine.
4. Reconnect the cable.
5. Turn on machine.
6. If problem continues you need the BICU
Dec 17, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Sep 25, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
176 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
