Question about Vizio L37 Television
Picture not filling screen on vizio 37" tv - Vizio L37 Television
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
There are a few buttons to adjust the picture size on different make TVs and even on the Cable/Satellite remotes .
1.Format
2.Aspect
3.Size
4.Zoom
5.Wide
6.#
First look on the TV remote, set it to Full ,Fill or Just.
Then on the Box remote stretch is usually best.
On the box remote set the output resolution to 1080i only
And use 16x9 when if offers a choice.
Cable remotes use the # key as a zoom button.
Due to the fact there are 16 size/Formats available (3 or 4 being transmitted now). you may have to hit the zoom/stretch button on some HD channels.
But with these settings the picture will mostly stay full and help you avoid image burn from the edges being not on the edge.
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 09, 2009
SOURCE:
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Posted on Jan 08, 2009
SOURCE: Borken LCD Screen on 37" Vizio HDTV
take it to sears repair shop. Most likely they will ask you almost half the price of the TV to repair it. It is a thin glass that is inside of it that is very fragile.
Posted on Dec 06, 2007
SOURCE: TV problem
I think the Vizio is defective. I contacted Vizio, gave them all information then got an email back requesting that I re-send them the info that was attached to their response. Duh! Anyway, our brand new Vizio 32" drops the picture and sound, remote can't control change channels or shut TV off. Also, the power button on the TV can't turn the TV off. Pulling the plug out of the wall seems to reset the TV and everything starts working again including the remote.
We have a sound problem, as well. You can hear one speaker (actor) and the rest are drowned out. Very weird. Sound doesn't track with the speaker (person).
Posted on Jan 14, 2008
  • 105 Answers
SOURCE: No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
Posted on May 22, 2009
  • 4 Answers
SOURCE: 37 inch vizio has black screen. the vizio display
L37HDTV10A THE TV ON NO VIDEO NO MENU SAON OKEY
Posted on Jan 21, 2010
Blue screen vizio vo371
Blue screen could be a bad main board or a no signal issue---do you get picture with DVD player connected?
Aug 29, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
VIZIO 37" LCD has sound but no picture
Good day!
that problem is happen when your inverter board is defective please replaced it..
This is the picture of inverter board.
thank you and good luck
Jun 10, 2011 | Vizio VU37L 37 in. LCD TV
When we watch a movie on our 37" vizio it's not going into widescreen it's smaller how do you set it up so it fills the screen
You can zoom in on the picture. But you are most likely watching a movie formatted for wide screen. There are different formats of DVD's. Hope it helps.
Aug 09, 2009 | Vizio VOJ370F 37 in. LCD TV
My vizio 37" plasma tv has a green line running down the right side of the screen
Vizio does not make 37" plasma TV. for the green line problem, does it happen on all inputs or just when you what TV (cable or satellite)? That line should only be present on some channels due to signal processing compatibility. To get rid of it, you can use the horizontal size adjustment and expand the picture side way.
Jul 03, 2009 | Vizio L37 Television
My picture 37" vizio hd tv does not fill in the whole screen when watching an HD channel
you need to change the aspect ratio on your cable box from 4:3 to 16:9. sould be under menu/setting/. if not try using the format button on the remote. hope this helps
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
TV problem
any luck? might 37" vizio just had this problem, all of a sudden no picture sound just fine, I call vizio and they say could be motherboard, do I bother fixing this, or just get a new one?
Nov 16, 2007 | Vizio L37 Television
Vizio 37'' TV
This is normal.
Oct 21, 2007 | Vizio L37 Television
Vizio L37 Television Logo
1,078 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
