Question about Milwaukee Tool Drills
Hi i have a problem with my v18 pd milwaukie drill/driver. The motor stop has stopped working and i would like to get it fixed. Any ideas?....
  • 2,176 Answers
Sure give me the zip code and city/state and I will try and find an authorized service station close to you. You can also send it direct to Milwaukee but a center closer would probably be faster. Let me know
Posted on Sep 09, 2009
Stopped working
battery or electric and what make?
Nov 29, 2015 | Drills
Milwaukee v18 battery runs down real fast
a battery in the battery pack is open circut Re: Jeff
Apr 06, 2012 | Drills
My Bosch 24v PSB 24 VE-2 has suddenly stopped working. The battery charges ok but when fitted into the drill , the drill makes a faint whining noise but fails to work. Any ideas ?
Hello
The motor windings in the drill are bad or have a bad connection.You may also try cleaning the battery contact points with a pencil eraser.
Jun 25, 2011 | Bosch Drills
18v xpr dewalt drill smells like buring then eventually stopped working or Intermittently works.
could be 1 of 2 problems, the motor or the switch, I would think more the motor. you can get some idea of what the cost would be by going to dewaltservicenet.com and typing in your model number for the parts listing. But also keep in mind that Dewalt has a MAX service rate that they will rebuild the tool up to the MAX rate for it, that includes batterys (or it used to include them)
Apr 03, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Hi, The jaws that grip the drill bits jam when closing approx 2mm in and will not close even close to a quarter of the way.
Has the bolt that holds the chuck on to the drill come loose? Did the drill get dropped? if it did it may of bent something. Have you tryed spraying it with WD40 to wash away any dirt that may be jamming it up. Hope this may help but with out looking at it I am only guessing.
Feb 05, 2011 | Milwaukee 0822 24 V18 Driver Drill Kit
Were are the brushes on this drill? I looked at parts list but did not see any brushes listed. Is this drill repairable?
there should be 2 plastic plugs that have a standard screwdriver slot in them,they should be towards rear end of drill,the plugs are flush with the plastic motor housing
Jan 18, 2011 | Milwaukee 0824 20 V18 Hammer Drill Bare...
Moderrate resistance stops the drill from driving and to scream
The grinding you're hearing is the normal sound for the clutch. There's a ring with numbers on it the higer the setting the more torque it'll take for the clutch to slip. Many of the newer drill & drivers have a drill setting at the high end of the clutch settings others have a separate drill & driver setting. This site will give you most everything you need.
http://www2.panasonic.com/consumer-electronics/support/Building-Products/Cordless-Tools/Drill-Drivers/model.EY7542LN2L
May 30, 2010 | Panasonic EY7542LN2L 14.4 Volt Li-ion...
Drill stopped work ing when hot. One drill we bought stopped after 10 6mm holes. The others work when you pull the trigger and then sometime they don't.
Sounds like a burned out motor.
Sometimes you can replace the brushes and make them work again.
When operating that drill, make sure that you are not overheating the motor.
Depending on the material that you are drilling, you may need to use the drill on a slower speed in order to not overheat the motor.
Another way is to have more than one drill, and switch to a cool one as soon as you notice heat on the in-use drill.
If your drill is battery powered, stop using the drill and change the battery as soon as the battery dies enough to slow the speed of the drill.
Operating the drill under reduced power is very hard on the motor for several reasons.
Oct 28, 2009 | Milwaukee Tool Drills
2 Milwaukee 18VDrills stopped working - NEED repair help
This may not be as easy as you think. The first one my have trouble with the trigger switch, but it could be the motor. Without checking continuity, or replacing them individually you will not be able to tell which one is bad.
Another problem could be the brushes. That is what is most likely wrong with the 2nd one. Remove the 2 black screw caps on the rear of the drill, and remove the carbon brushes. Do they look worn? If so they will need to be replaced. If this is the case the motor may be breaking down, and wearing the brushes down too fast.
The good news is that Milwaukee Tools, offer a 5 year limited warranty, If you have a receipt, or can read the serial number. Take it in, or mail it to a service center. They will take care of it for you if they are less then 5 years old.
Dec 29, 2008 | Milwaukee 0822 24 V18 Driver Drill Kit
Dewalt 18 volt cordless hammer drill
You should try to charge the battery again. Or you can try to fix it or then its time to get a new battery.
May 10, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
128 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
Harjeet Singh
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
