Question about Farenheit TID-840 6.5 in. Portable Television
Farenheit DVD/TV/AM/FM Receiver - TID-895
The battery to the van was disconnected and now the tv will not turn on. Is there a reset button or a reset access code?
  • 10,865 Answers
I would begin by checking the fuse for the socket you have this device plugged into. Whenever possible, all accessories should be unplugged and the radio should be turned off before you disconnect the battery. good luck.
Posted on Jan 21, 2009
  • Tameka Caradine
    Tameka Caradine Nov 11, 2013
    ill try that but what if it doesnt work??? where is the rest button on TID-580
  • repairyes Nov 29, 2016
    I thought this was for the TID-895
    Tameka, I would remove the power connection to the unit for a couple of minuter, then plug it back in. Then test. I didn't see a reset button mentioned in the manual.
    Cookie Goode, there is a reset button on the lower right hand side of the front panel. These are old posts and perhaps you have already replaced the unit.
Farenheit TID-400 Car DVD Player manual
Try to find it at [url="http://www.justcardvd.com"]overhead dvd car player[/url]
Mar 28, 2013 | Farenheit TID-400 Car DVD Player
Hi i have a Farenheit tid-530 and when i play the cd on the dvd player it randomly turns off and switches to the fm radio is there any solution or is there a problems with the wires?
When mine did this i bought a cleaning disc and it stopped this. Untill a few months later. Just use it once a month or so and it shouldnt happen anymore.
Jul 10, 2011 | Farenheit TID-530 Car DVD Player
I need a printable or downloadable manual for the fareheit in-dash cd/dvd player that just came in the car I purchased. I have no clue how to work it.
I wasn't able to find the manual for the TID-403, however, I did manage to find the one for the TID-360.
It's probably worth reading through, because it may have the same standard button combinations.
http://www.farenheitusa.com/manuals/sourceunits/tid360.pdf
Mar 01, 2011 | Farenheit TID-403 Car DVD Player
Not being able to watch dvd player while in park,can hear dvd,but nothing on screen
this is due to a safety feature fitted on the system that only allows you to watch the DVD when the park brake is on. the only way you can get round this is to disconnect the wire on the park brake, and earth it to the vehicle chassis
Mar 15, 2010 | Farenheit TID-895 Car DVD Player
My audiovox remote will not turn on tv or change channels - I put in new batteries. I pressed the TV function button to reset but is does not reset to use the tv or dvd
Try put again the batteries.A very simply and efficiently mode to see the remote control is work or not to tested of pressed taste next on radio posted on FM or MW.
Aug 21, 2009 | Audiovox Televison & Video
Tv not working
if you place it on the windowsill so that it's just hanging and it falls off at the slightest touch. that'll fix it.
May 18, 2009 | Farenheit TID-840 6.5 in. Portable...
Black and white image
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 27, 2017 | Farenheit TID-730 7 in. Portable...
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
Farenheit TID-840 6.5 in. Portable Television Logo
342 people viewed this question
Top Farenheit Televison & Video Experts
Are you a Farenheit Televison and Video Expert? Answer questions, earn points and help others
