Not blowing air
Was told to remove the filters and clean them
but where are the filters and how do you find them
  • 3 more comments
  • beaufighter4 Sep 09, 2009
    unit works but not much air moving tru they have told me to remove the air filters and clean them but do not know how to do this and where they are in the unit this is a rv roof top model
  • mac5932002 May 11, 2010
    what type of unit is it
  • John Pappano May 11, 2010
    What type of unit is it.
  • please what type of a/c window or split or package...etc and model.
  • bozcro
    bozcro May 11, 2010
    what type of ac is this, r/v, home, portable or window?
    Problem Solver:
  • 11 Answers
Where the air goes inside the inside unit
Posted on Sep 13, 2009
2 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: Blowin warm air, filter cleaned
Hello there:
There may be a small leak in the compressor that may have leaked out the refrigerant or on of the lines may have a pinhole leak in it
I would first have the unit recharged using a recharge kit and than check for any leaks also make sure that all of the fins on the compressor in the back are not damaged and are clear if you have a water howe spray the entire back down real good and if none of this helps than i would susspect a faulty temperature regulator or switch ok?
so please try all of these things that i have mentioned and let me know how this goes for you
Best regards michael
Posted on Nov 14, 2009
Fan on air cleaner blows out top but does not suck
If air is blowing out - it most assuredly is getting in. The area of the intake make be large enough for you to perceive air being sucked in.
Make sure ALL filters are clean. Remove and replace disposable filters or wash and replace permanent filters. Do this for pre-filters too. Then, try again.
Oct 23, 2015 | Hunter 30200 Air Cleaner Purifier Filter...
How to remove air filter on 2001 fxst
Remove the screw and air cleaner cover, remove the three TORX screws and the bracket from the filter element, gently pull both rubber breather tubes from the back of the element, remove the filter element and gasket, replace the filter element if damaged or if filter media cannot be adequately cleaned, gently pull the breather tubes from the breather bolts on the backplate, clean the filter element by washing the paper/wire mesh air filter element and the breather tubes in lukewarm water with a mild detergent, do not strike the filter element on a hard surface to dislodge dirt, allow the filter to either air dry or blow it dry from the inside with low pressure air. Do not use air cleaner filter oil on the Harley-Davidson paper/wire mesh air filter element. c. Hold the filter element up to a strong light source and if light is uniformly visible through the element, it is sufficiently clean.
May 09, 2014 | Harley Davidson FXST Softail Standard...
I need to clean an air filter for a john deere 55ev chainsaw
just wash filter in petrol and blow of with compressed air , I would also remove spark arrester from exhaust and clean that by burning carbon of then blowing with compressed air , if you chainsaw still runs bad it needs carby serviced and retuned .
Mar 28, 2014 | John Deere Garden
E-1 code were are the filters ? how long are the
In order to find the fuel and air filters you must first remove the top section of the heater tube, this is done by removing the six to eight 5/16" hex headed screws. Now once the top section has been removed you will have access to the fuel lines, they vary in length as to where they go so a simple measurement takes care of that situation. Filters are as follows, the air filter is at the back of the heater assembly, it is usually a foam filter and it is in the air pump ( black plastic pump). Then there are actually two different fuel filters, first one is a screen filter just behind the fuel nozzle. You have to remove the fuel nozzle and there is the screen filter, while you have the nozzle out you can clean it by using a blow gun and compressor to blow air thru the nozzle and make sure there is no blockages. The second is located under the side cover, so trace your fuel line down to where it comes thru the heater tube and again remove the 5/16" hex head screws to expose the fuel line. Now some have the filter right there in plain sight and some depending upon the year have it in a grommet in the fuel tank top.Again remove it and I clean it the same way with compressed air blowing backwards thru it as well. Make sure that you have tight fits on all fuel and air lines, make sure the nozzle is clean ,the screen filter is clean, and put the nozzle assembly back together. be careful not to damage the nozzle.While you have the heater down make sure to clean the flame sensor, for this I use windex and a soft terry cloth rag. Put the heater tube back together and you are ready to test.
Jan 09, 2011 | Dayton E51 Oil Filled Utility Heater
Heater runs for 30 sec then shuts off blows smoke and gives e-1 error code
I am not to sure of the trouble codes on Mr.Heater but this is usually a fuel related problem. My routine maintenance is remove top half of heater and clean fuel system from nozzle back to the tank.Remove nozzle,clean the screen behind the nozzle they corrode over the summer sometimes inspect the nozzle for corrosion or damage. Inspect lines back to pump then to filter. The filter can be cleaned out with compressed air and a blow gun blowing air thru the filter backwards. Now check the fuel line to the tank and make sure it is submerged in the fuel. Before putting the top on locate the fire sensor and give it a quick cleaning with windex and soft terry cloth rag. Put your heater back together and check air filter to pump clean it and fire away. This works 90 percent of the time. Good luck!
Dec 20, 2010 | Mr. Heater MH175KT Open Flame Utility
How do you clean the filter?
remove the front grill that has the filter fittted on the grill end. remove and use a fine brush and aided with an air jet blow into the filter and remove off all the dust that is on it.
You can also use good detergent to wash off dirt and dry the filter but without any harsh brushing.
Now set this back but make sure to clean the inlet of the cooling
fins.
Sep 01, 2010 | DeLonghi CF210 Portable Air Conditioner
I have a panasonic PT-50LC14. the clean air filter display keeps coming on. I removed the housing for the lamp and cleaned all that area then i removed the back of the tv and cleaned the vents. i watched...
When you take the back off the tv there is a metal brace in the center of the set with pc boards on it , remove the screws and this will swing to the left like a door, take care because some of the wires will have to be unplugged to get it out of the way, then you can see a black plastic box on top of the light engine , remove the cover and you will see the filter remove it and clean it, then replace everyting in reverse order. Hope this helps.
Dec 16, 2009 | Televison & Video
How we can clean airfilter because message is appearing regarding clean your air filter
check in the menu to see if there is a filter timer that you can reset. if so, reset it. if not, there is an air flow sensor on the projector that will send that message if the air flow is decreased so the projector does not overheat. find the filter and remove it. blow it out with canned air and blow out the projector as well. replace the filter and enjoy!
Nov 05, 2009 | 3M X50 Multimedia Projector
Ac cooling but not blowing very hard
The AC filter of your car should be under the dashboard on the passenger side. While you have it opened it would be best to go right ahead and have other components clean to save you time.
Jul 22, 2009 | 1996 Saturn SL
Kenmore 73259 wall unit a/c blowing out black particles
remove the filter aand run it and see what happens, the filter still could be causing the issue
Apr 25, 2008 | Kenmore 73259 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
