Question about Refrigerators
Sub zero 532 - Changed fan motor. Front of the box is very hot. so is the condenser area. fan running.
Alot of subzeros have two comp one for fz one for ff if you do first make sure comp to ff is ok and frean level is ok next check the therm to ff and finnally check that the air flow in the ff is not blocked up
Posted on Feb 20, 2012
  • 34 Answers
Sounds simple, but did you clean the condeser coil.
Posted on Sep 10, 2009
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
Door gasket Very hot and also metal strip very hot asa well
Check if condenser fan motor is running and condenser unit - it might be full of dust and lint - clean it! It is dangerous for both compressors if that fan motor has stopped working! These parts located on top behind that alluminum grill, on right hand side. Sub Zero refrigeration condenser cleaning - Read instructions here:
http://www.subzerolosangeles.com/how-to-clean-a-condenser-on-a-sub-zero-refrigerator/
Sub Zero refrigerator repair service and parts in Los Angeles
Jul 21, 2014 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 736 condenser fan not running
You will need to remove the cover around the condenser fan motor then remove the screws holding it down to the base. Remove the wiring from the junction box and away you go. Do not run the unit without a working condenser fan motor, you run the chance of causing yourself many other problems. With a new fan motor the unit should run fine unless there is waxing in the cap tube from overheating. Good luck
Sep 08, 2012 | Sub-Zero Refrigerators
Just had the condenser fan motor replaced on my 550 sub zero refrigerator. I forgot to asked the serviceperson the following questions: Does the fan continously stay on and what is the normal sound of...
Good day,
On models with 2 compressors the condenser fan motor runs 24/7. It must since the compressors run randomly and that motor must be on since it handles both units.
Fan noise is subjective. It itself makes little noise but the blade does. If for example the blade was changed from the nylon style to a metal blade (good idea) then it would be somewhat louder.
If the noise is not objectionable then I would use it as is.
Oct 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
532 sub zero evaporation tray is filling up with a
This is only normal in an environment of high humidity. My question is the condenser fan blowing over the condensate pan and is the air hot enough to evaporate the water that is in the pan? Has covers been removed on the rear of the refrigerator that may cause a different flow of air. Are all covers in there correct place and not missing panels that could change the flow of air over the pan? Let me know, Thanks, Sea Breeze
Aug 26, 2009 | Refrigerators
My sub-zero frig is running hot on perimeter strip
Usually, this either means that you have a dirty condenser unit or a faulty condenser fan motor. Check behind the top acess panel to the right and see if your condenser is clogged with dust. Also, check that the fan motor up there is going whenever the compressors are running.
Oct 18, 2008 | Sub-Zero 632 / S
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 532 not cooling
Simple think I guess - just pull down a little a plastic fan blade on motor shift it will produce a powerful air flow. Fan blade should sit pretty close to the shift end. ;)
_______________________________
Los Angeles Sub-Zero refrigeration experts
Jun 11, 2008 | Sub-Zero 632 / S
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
