Question about LG LRSC26910 Side by Side Refrigerator
Wont call for water
There no water in the ice maker,u can fill it from a cup it works but it wont fill up with water
  • todd72472 Dec 11, 2007
    still not getting water
  • 25 Answers
Is the valve behind the refrigerator opend?
If yes, you intake water hose can be frozen, if so, defrost the fridge manualy.
Posted on Dec 10, 2007
The ice maker on my Kitchenaid KBF320EVMS4 french door refrigerator stopped working. The drinking water works fine and I can hear the noise when the ice maker fills with water but no water comes in.
you can pop the cover off of the ice maker,on the module you'll see some letters,if you get a jumper wire and stick it into the T and H the ice maker should start to spin,if it doesn't the ice maker is bad,then remove the wire and stick it into the V and L,water should start to fill the ice maker,if it doesn't most likely you have a bad water valve,just get a piece of wire,strip off both ends to make a jumper wire.one more thing,check the fill cup and the fill line to see if there's any ice in there,if the water valve is bad water can drip through and freeze in the cup or fill line stopping the water from entering the ice maker,if there is melt it out with a hair dryer,also if you have to get in there with a hair dryer be careful with the heat on any plastic parts,you can damage it and don't heat the fuse on the ice maker wires,it's a black fuse built into the harness you can damage it if it gets to hot.you can go here to see your parts
https://www.searspartsdirect.com/model-number/KBFS20EVMS4/0593/0161000.html?searchType=modelSearch&q=KBF320EVMS4&searchTerm=KBF320EVMS4
Nov 22, 2017 | KitchenAid Refrigerators
Every time ice maker runs, water accumulates at the bottom of the fridge. It is a bottom freezer model made 9-2013. What could be plugged?
Check the ice maker fill cup, it could be full of water or ice and all the water misses the ice maker. Check the fill line in the freezer to make sure its in the full cup to the ice maker. CHeck the drain under the evaporator in the freezer to see if it is open and obstructed. Thats what I would look for. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 20, 2016 | Refrigerators
Ice maker is not making ice.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
Jun 04, 2015 | Refrigerators
Install nocold refrigerator icemaker
Jun 02, 2015 | Refrigerators
Ice maker wont work
The ice maker gets its water from the filter too. If there is NO water getting to the ice maker then look at the solenoid that lets the water into the ice maker. If water seems to be frozen to the underside of the Ice maker, take the unit out and allow it to dry before putting it back in.
Jan 14, 2014 | Samsung RS267TDBP Side by Side...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
Sep 16, 2009 | Refrigerators
GE SSS25KFMD SIDE BY SIDE
you might have a bad water valve that it wont close since your just repl ice maker then try to repl water valve at back if is leaking then the fill cup will be full of ice and also it will be over filling the ice maker mold
Oct 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
check the fill cup on the back of the ice maker for an obstruction of frozen ice, it the fill cup is frozen over then the water entering the ice maker will cascade over the frozen ice down into the freezer
if frozen melt it with a hair dryer then it will be ok
Apr 20, 2008 | Maytag MZD2752G Side by Side Refrigerator
LG LRSC26910 Side by Side Refrigerator Logo
75 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
