Question about Honeywell Programmable Thermostat Heater
Seco thermostat model # tb1540e-g to a Honeywell RTH221B1000
I see on the Seco there are 5 Terminals as follows:
R which has a red wire to it
W Which has a White Wire to it and a Red That Jumpers to The Terminal Label F Below
Y Has a Blue Wire to it
F Has the Jumper running to W
G Has a Green Wire To it.
On the Honeywell There are 5 Terminal
Y
G
Rh
Rc
W
I am not sure which wire should go where any help would be appriciated. I am disabled and can't afford to get somebody to do it. I figured I could handle it but of course wires aren't right colors.
Thanks So Much
  • 1 more comment
  • willgolf4fun Sep 12, 2009
    Yes it is all electric. No Heat Pump either. Also the TerminalI see labeled as a F could be E as the wire could be covering it a little.
  • willgolf4fun Sep 15, 2009
    A very nice Heating and Air Conditioning Man I talked to gave me the solution to my problem.without a charge.
    It was for my wiring since the Y wire is Blue the wiring is as follows and it took about 10 minutes, Besure to shut of the power to the Furnance Breaker and verify no 24V to thermostat.
    Blue to Y
    Red to Rc and jumper if not already installed to Rh(Mine already had it installed.
    White to W
    Green to G
    Then program the unit with the instructions and it is working great.
    Hope this helps other.
  • Richard Johnson PE
    Richard Johnson PE May 11, 2010
    Your furnace is electric heat?
  • Honeywell Expert
  • 252 Answers
Red to Rh AND Rc, white to W, blue to Y, green to G,
Posted on Oct 04, 2009
Have a pellet stove and a thermostat can be hooked up to it. there are only a place for two wires. but i don`t know where to wire them on the thermostat rth2310b
You will use thermostat wire and use the red and white wires. Terminals should be marked (R) this being red and(W) this would be the white. Follow the same way on the thermostat and this should do it for you. Good luck!
Dec 12, 2010 | Honeywell Programmable Thermostat Heater
My old thermostat has only yellow and red wires...no green and white like my new Honeywell thermostat installation instructions mention. Is this a problem?
The green wire is used to turn on the blower if you want constant air circulation. For heat only, the red and yellow wire will work as long as they are connected to R and W terminals on heating unit (or TH and TW on some models).
Nov 20, 2010 | Honeywell Programmable Thermostat Heater
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Wiring honeywell DT200(T6620B)
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Apr 11, 2009 | Honeywell Programmable Thermostat Heater
I am changing from a Seco control thermostat model # tb1540e-g to
Rc/Rh should be from the transformer if a single transformer system. If its'a dual transformer system, then there should be a red wire to each from it's respective unit (furnace=Rh, condensor=Rc.).
W should be heat.
Y Should be cooling.
G should be fan.
I am not certain what E is, unless the stat can be used on a heat pump with backup electric heat, in which case it's for the electric heat.
The reason I say should be, is because if you are looking at wire colors, and not terminal designations, there is no guarantee the control wiring was connected following normal convention.
Reply back of any further questions.
Feb 03, 2009 | Honeywell Programmable Thermostat Heater
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Dec 20, 2008 | Honeywell Electronic Programmable...
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
638 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
