Question about Samsung SyncMaster 204B 20.1" LCD Monitor
LCD monitor I wish to replace a 19" CRT monitor which I use with an 85 or 100 Hz refresh rate with a 24" LCD monitor for all computer activities. What monitor(s) can you recommend to minimize eyestrain due to "flicker".
    Genius:
  • 1,003 Answers
SONY MFM HT75W
Posted on Jan 16, 2008
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
F the "Hz?" In a rectangle appeared on the dark screen, what does this mean?
This refers to the "Hertz" which is the refresh rate of the monitor. You should refer to the manual and look under refresh. If not, you can select the different settings until satisfactory. A lower number is easier for the video card to handle, higher setting require more work for the card.
Sep 30, 2010 | Samsung SyncMaster 997MB (Beige) 19" CRT...
After Windows has started and the setup screens show, my Kogi monitor says "out of range" and the screen goes black. How can I fix this?
Set the resolution lower.
It is telling you that the resolution you want is beyond its normal operating range.
just drop it to lets say 800 x 600
Then bump it up one resolution at a time until you get the message again, then drop it back one.
Running monitors above the acceptable range can drastically shorten their lifespan.
Sep 06, 2009 | Computers & Internet
Screen shift
Try setting the refresh rate to 60 Hz. (Maybe 75).
Is it xp?
Right click an empty part of the screen, properties, under monitor (I think; I'm on Vista) you can choose the refresh rate.
Most LCD's should be at 60 Hz.
Jul 04, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Monitor into TV
The monitor may not be compatible with your TV box. Basically if the monitor can't handle the refresh rate or resolution a blank screen like this will result. There should be a way to change the refresh rate or a standard refresh rate listed in the manual. What brand/,model of tv box is it?
Dec 12, 2007 | LaCie Electron 22" CRT Monitor
Refresh rates and resolutions
What's the question? There's no real need to go above 85Hz, I think in nvindia you have to go to an advance menu and you can force an output, google it.
Dec 12, 2007 | iiyama Vision Master Pro 510 22" CRT...
TFT Problem
This LCD can work at 75 Hz refresh rate, btw much more healthy for your eyes, you can change it accessing Control Panel -> Display -> settings -> Advanced -> Monitor -> Screen Refresh Rate -> select 75 Hz.
Dec 07, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
77 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
