Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load from may of 06 Code E20 Model GLTF 2940ES3
I have read that this most likely means a clogged drain hose, or a clogged pump.
I am not sure how to remove the front access panel.  I am a beginner with this washer.  I was very familiar with my old top load, but this is all new to me.
Please help.
I had the same problem with the same model use directions above to get to pump area, there is a rubber booty that goes in between the drum and the pump, take off the booty and inside there is a filter, mine was clogged with various small items.
Posted on Jan 20, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Not famil with you model. Most are either pull off or two screws on the lower front kick panel once removed there should be a cap unlock or unscrew to left...counter-clockwise. Some of the latest are only accessible from underneath.First thing to do....bring it out and lean back against wall.. see if pump is attached to front panel to see which way to access it. this will also stop water flow from drum.
Posted on Jan 01, 2008
Error code E20
Hello igor_lyub - Typically error code E20 means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 12, 2013 | Frigidaire ATF6000ES Front Load Washer
Filter replacement for frigidaire gltf2940es
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire GLTF2940ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Code E20
Oct 12, 2012 | Frigidaire Affinity ATF6000F Front Load...
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Aug 21, 2011 | Frigidaire Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
WHAT DOES E20 MEANS ON A FRONT LOAD
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then clean the debris from the pump. Make sure that you have a container to collect water nearby when you are removing hoses from the pump, as ther would be a lot of water. Please post back for any further assistance.
Daniel
Aug 02, 2010 | Frigidaire Affinity ATF7000ES Front Load...
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code e20 model # gltf2940ee0
Hi
Daniel
Jul 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
287 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
