Question about Whirlpool Gold Black-on-Black 25.4 cu. ft. Side-By-Side Refrigerator w / Accu-Chill Temperature Control System GD5SHGXLB
My Whirlpool Gold Dishwasher isn't cleaning
The dishes are going in cleaner than they are coming out. The detergent sometimes remains in the dispenser. I have cleaned it thoroughly, set it on pots and pans cycle with scrub and scour option.. still not cleaning.
The dishwasher is approximately 5 years old.
  • 725 Answers
You need a new water valve. Call us for parts and supplies for your Whirlpool dishwasher. We will be sure to get the correct part out to you right away! We look forward to hearing back from you soon.
Posted on Sep 10, 2009
My dishes are cloudy and all the glassware and pans are cloudy and striped with detergent. I have tried 2 times to use a dishwasher cleaner, yet the problem remains. Any solutions?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Apr 19, 2011 | Whirlpool Dishwashers
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2200 dishwasher, the detergent
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Aug 27, 2009 | Whirlpool GU2200XTSS Built-in Dishwasher
The dishes are coming out all cloudy and seem to have a film on them. It is a powdery substance that will not wash off even by hand. It is ruining my dishes. It doesn't matter what soap I use.
Be sure to use a good quality detergent or tablet with rinse aid built in... but before that I would go buy a dishwasher cleaning solution. These are usually in a bottle and you just sit the bottle in the dishwasher by itself (with no other dishes) and run a normal washing cycle. The cleaner will clean the inside of the dishwasher, including the drain area and help produce cleaner dishes thereafter. This should be done every 3-4 months as standard.
Aug 19, 2009 | Whirlpool 24 in. Portable Dishwasher...
The top rack is not longer getting clean
Using liquid detergent is the worst detergent to use. One possible solution to your problem could be as follows...pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. May need to do this several times (3 to 4). This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel, no liquid and no tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
"clean" light is blinking
Check the following:
1. Is the overfill protection float able to move up and down
freely? Press down to release.
2. Be sure the water supply is turned on to the dishwasher.
3. Check for suds in the dishwasher. If foam or suds are
detected by the dishwasher sensing system, the
dishwasher may not operate properly or may not fill with
water.
Suds can come from:
1. Using the incorrect type of detergent, such as
laundry detergent, hand soap, or dish detergent for
hand washing dishes.
2. Forgetting to replace the rinse aid dispenser cap
after filling (or refilling) the rinse aid, or spilling rinse aid into the tub (rinse aid causes suds to occur).
3. Using an excessive amount of dishwasher detergent.
Mar 16, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My whirlpool gold doesnt clean properly there is a sandy residue
Sounds like you have a calcium issue with your water. if you have a water softner time to get it serviced. also you can get a cleaner for the dishwasher to clean it out called Dishwasher Magic.
Dec 04, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Feb 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Refrigerators Logo
143 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
