Question about Power Acoustik TS1440-2 Synchronized Lightning Pulses 2 channel 1440W PLASMA SPHERE Amplifier Car Audio Amplifier
Watts how come the watts on the amplifier say 1920 and on the information it says that its total power is 1440??
    Top Expert:
  • Power Acoustik Master
  • 80,530 Answers
One is peak power the other is the more accurate RMS power.
Posted on Sep 09, 2009
IM67 sound system
The center speaker 900 watts, the two speakers on sides 300 watts each and the subwoffer 500 watts. Total of the speakers power 2000 watts.
Sep 02, 2012 | Fellowes AE10 Amplifier
I have a mosfet GM-x742 how many watts is that i dont now how many watts that is
Here are the specifications for this amplifier: (channels)x(# watts rms) @ (Total impedance)2x80wrms @ 4 Ohms
2x120wrms @ 2 Ohms
1x240wrms @ 4 Ohms
Feb 25, 2011 | Pioneer GM-X742 Car Audio Amplifier
I just installed a 1000 W 3-way toggle dimmer for a load of 12 75 W recessed lights, each holding 65W bulbs. When I turn the lights on, the metal plate around the dimmer gets very hot. Is this normal?
The watt rating is absolutely critical to the operation of the device.
The high heat is a direct result of too much amperage flowing through the dimmer.
Reduce your wattage immediately or stop using the dimmer.
You have a fire hazard.
According to the math, you have 20 - 65 Watt bulbs
Change 12 of the bulbs to 40 watt and you will drop to the 1000W max.
12 x 40 = 480W
8 x 65 = 520W
Total = 1000
However I am worried about this circuit.
A typical 15 amp switch (not a dimmer, but the switch) is maxxed-out at 1440 Watts.
So if you had 20 100 watt bulbs for 2000 Watts, it would heat up the 15 amp switch
It seems very odd that an electrician would put 20 lights on one circuit without having a 20 amp switch and 12 gauge wire.
Look at the markings on the switch you replaced and look for amps or watts.
And then look at the color of the wire cable inside your box ... 12 gauge wire is yellow and the lighter-weight 14 gauge wire is white.
If you have a white wire going to all those lights, then you are going to burn down the house unless the total wattage is reduced.
Volts X Amps = Watts.
I think your circuit needs a review to make sure it has the correct wire.
http://waterheatertimer.org/Color-codewire2.html
This being said, Lutron makes 1800 Watt dimmers.
You can web search: 1800Watt single pole dimmer
If you have yellow-colored 12 gauge wire, it can carry up to 1920 Watts
If you want more help, add a comment and I will answer
Nov 04, 2010 | Lutron 1000-Watt Incandescent Dimmer...
Can you tell the wattage of the onkyo tx 905 not the home theatre model stero only
140 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of 0.05% (FTC)
170 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven at 1 kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
180 watts minimum continuous power per channel, 6 ohm
harmonic distortion of 0.1% (FTC)
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
What sizes fuses go from battery to the amp on the kole audio 1920 watts kx2-1920?
depends on the size of your amplifier. what size is it? and how many channels? and what class?
Oct 22, 2009 | Kole audio KX2-1920 Car Audio Amplifier
Mtx audio 4252 amplifier
Hello freshman_fox,
63 watts X 2 @ 4-ohms.
125 watts X 2 @ 2-ohms
250 watts X 1 @ 4-ohms bridged
Since no power rating is given @ 2-ohms in bridged mode, it means that the amp is only stable to 4-ohms.
The manual does not specify a peak power, but since RMS is about 70.7 of peak, that makes it 353.5 watts.
You can download the manual from here. Hope this helps.
Jul 10, 2009 | Car Audio & Video
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Home stereos
Hi this is Compaqowner again NOTE: I know enough about home Stereos,and I am pretty sure to figure out 'power output' you take the total:in this case it takes in 110 watts total devide that by 2 so according to my math that is 55 watts (I guess this AKAI has a 55 watt amplifier) then you take the amplifier output (in his case 55 watts) and devide that by how many channels are being used,so in 5.1 DOLBY mode DVD movie,etc.(power to all 5 speakers) then it's 11 watts per channel,and in 2.1 stereo (power to the subwoofer,front right,and front left speakers only) it jumps up to a little over 18 watts per channel,again,I think?,when you find the answer,please let me know. Thank you for your time. Steve B.
Nov 03, 2007 | Audio Players & Recorders
Speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
Power of amplifier
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Aug 27, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Power Acoustik TS1440-2 Synchronized Lightning Pulses 2 channel 1440W PLASMA SPHERE Amplifier Car Audio Amplifier Logo
69 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
